Dh4276
I had a preventable injector failure last week that I have not seen anyone post about, but I could have missed it. There is a Plunger/Pin (different sources call it different) that sits under the rocker arm and on top of the injector.
At over 247k I had one of these pins spilt in half causing the injector to stop working due to being out of adjustment. Unfortunately I was 185 miles away from home and was not able to fully fix the problem until I got the car home. I adjusted the injector as best I could and got her home. After ordering a set of injectors, I found this piece came with the seal kits I ordered to but the new injectors in with.
When I took the rockers off to change the injectors, I found the the others were worn badly as well.
I would recommend checking these pins/plungers anytime you have to remove the valve cover so that you can prevent any failures and damage to your PD injectors.
