Im gonna try this mod but there has been too much confusion here.
Kerma posted:
Fuel temp sensor: pin 7 = yellow/bluestripe
pin 4 = brown/blue stripe
IAT sensor: pin 1: brown/ blue
pin 2: Grey/ Green
And to put a 2.2k ohm resistor in series (inline) with ONE of the wires for each sensor. But people are getting CEL codes if they choose the IAT pin 1 (brown/blue) wire. And non-starts when using pin 4 (brown/blue) on the FTS.
Why?
Cause:
http://www.geocities.com/tech4tdi/pages/map.html
Pin 1 is the ground wire for the MAP/IAT sensor. People forget that it is a shared sensor. So if you put a resistor on pin 1 (brown/blue) for the IAT sensor, not only do you lower the temp reading, but you also mess up the "Manifold Pressure" reading (MAP).
I don't have a wiring diagram for the Fuel Temp Sensor (FTS) but I think it is safe to say that the FTS harness has more than just a temp sensor. So which one do you think the ground is? Probably the (brown/blue) again right?
This is what Rub87 was saying about not cutting the ground wire.
I will try this mod for myself soon and will post or edit any changes.
Who here has had success with this? Either power, smoke, or econony.
Who has done it correctly and have failed to improve?
What truly is the best resistance for each sensor?
What has been the recorded temp readings for the Fuel and Air with what resistance?
Anybody use variable resistors?
