dabear95
DOH! Thanks!
I repeated something I'd heard, about hot fuel causing retarded timing and reduced fuel economy.Mike_M said:I remember that gdr703 or TornadoRed or somebody had said something about hot fuel and/or air actually combusting better elsewhere, but I can't find that thread now.
I don't...do you have a link to a thread?spoilsport said:Anybody else remember SkyPup's IAT heat doping mod?
What am I, your research monkey?!Mike_M said:I don't...do you have a link to a thread?
Mike
YES! Just kidding.spoilsport said:What am I, your research monkey?!
Always a good idea, for those of us who weren't there or didn't see it at the time. And I thank you for that.BTW...I'm not advocating this mod. Just thought I'd bring some historical perspective to the discussion.
And this is from a later message discussing why WETT (at the time) didn't increase boost more than they did. I think it's germaine to the discussion, and implies a reason not to fool the IAT sensor.SkyPup said:Once the engine has warmed up to operating temperature as indicated from the Engine Coolant Sensor and the Fuel Temperature Sensor, the underhood temperature is apparently 120-150 degrees F. ... The IAT sensor itself is heat doped to this temperature too, as will everything else under the engine hood while in operation. When throttle is applied ... the turbocompressor air output instantly becomes greater than [225-325 degrees F]. This heat blast instantly hits the OEM VW intercooler which has about a 60% efficiency ... giving a resulting post intercooler air temperature at the IAT sensor of about 200 F. Optimum intake air temperature for a diesel engine is about 100-120 F., air heated above that temperature is less dense and adds various stresses to the combustion process. [Right, that's why we have FMICs available.]
[A]n easier method ... is simply to wrap the IAT sensor in a custom fitted polystyrene-polyurethane insulator, thereby decreasing its "doped' idle temperature reading by roughly 30-40 degrees F. and slowing its control on decreasing the fuel quantity injected at the injectors by taking away its "heat doped" baseline reading. ... The entire MAP/IAT sensor is now protected from underhood heat doping by being surrounded with a heat insulator. Preliminary results indicate that both the torque and throttle response have been improved[.]
I'm certainly not questioning Kerma's skills or knowledge...that's been proven. Just wanted, as spoilsport said, to bring a little history to the table.SkyPup said:EACH AND EVERY INCREASE IN INTAKE TEMP is directly transferred to combustion chamber temp, EGT, etc. and stresses the pistons, valves, etc..
While fooling the IAT sensor may make this an issue it isn't an issue if yu have an EGT gauge.Originally Posted by SkyPup
Oh, I know that. I'm just wondering about whether it's better for the engine to actually cool the air and fuel as opposed to just telling it you are.Slave2school said:We're not really putting hotter air in the car, my setup hasn't changed any but just what the computer thinks it has going into it for air.
No worries...I got that much, and I appreciate that.Slave2school said:Oh I'm not preaching to you Mike, I read through most of that other thread too and I'm just making observations.
True, but the stakes are a bit higher for me, I think. Average daytime summer temp in Phoenix is about 103-105°F. The highs are at least 80°F for about 9 months of the year.Slave2school said:I'm not worried about the plastic poorly conductive pipes getting that hot from the engine bay 3 months out of the year here. If I lived in the south I wold be a bit more concerned, but still...it is plastic how conductive is plastic compared to metal pipes that are in all the aftermarket kits!
Hmmm..fabricators? is John @ EuroJet listening?Slave2school said:Personally I'd like to see a finned metal pipe from the turbo outlet to the intercooler since the ambient air temp is always going to be less than the output from the turbo.
In a 2000 Golf, it's on top of the intercooler. You may have to remove the wiper fluid reservoir to get at it.baun said:so weres the air intake sensor at? i cant seem to find it
Question: Could one bridge the two pins with the resistor, thus setting a fixed resistance value in place of the sensor, rather than adding a resistance?KERMA said:Fuel temp sensor: pin 7 = yellow/bluestripe
pin 4 = brown/blue stripe
IAT sensor: pin 1: brown/ blue
pin 2: Grey/ Green
Here is a table with the different resistances at various degrees C in case you want to try different resistance values:
C Ohms
0 5000-6500
10 3350-4400
20 2250-3000
30 1500-2000
40 900-1400
50 700-950
60 530-675
80 275-375
100 150-230
This table is the same for IAT and fuel temp.
Whoa! I missed that mod. What is that, how does it work, and where can I get one? Do you have a link to the thread where it was (I assume) discussed?dabear95 said:I am also interested in Kerma's thermostatic "T" replacement but I'm not sure I want to run it for 8 months and swap it out for the rest of the year...
That isn't the same, by doing what you are doing you are lowering the resistance of the sensor, by putting the load in parallel.rotarykid said:Instead of cutting wire & soldering the resister into the wire why not just bridge a resister across the two wires ?? Wouldn't that work just as well ??
I miss read the chart I thought the ECU would get a colder fuel temp from a lower resistance .woofie2 said:That isn't the same, by doing what you are doing you are lowering the resistance of the sensor, by putting the load in parallel.
you need to increase resistance by putting the resistor in series.
