hi all
i have an a4 1.9 tdi (110) 1996, AFN engine code with wastegated turbo. i had some recent power problems with the turbo not kicking in which was fixed by replacing a split hose. on my first test drive i got some black smoke but other than that and all seemed well but when i pushed it hard i lost most power! i limped home tried again the following morning and the car wouldn't start!
when i try to start the car the engine just spins and spins, there is absolutely no change in noise to indicate it may start. i had a recovery service come out and after a few elec tests he diagnosed a faulty diesel pump. great an £800 exchange part + fitting! when he left he told me he was not a diesel specialist which left me with some hope he may have got it wrong.......? i checked the troubleshooting & maintenance link on this forum and it say's that to diagnose a faulty pump is done with the engine running and diagnosis in vag-com. does this mean that the car would still start even if the pump is faulty? i pulled the pump relay out and this stopped the pump switching so it seems to be getting electric.
i have checked to see all the hoses are in place and they are, i've looked to replace relay 109 but i don't actually have one! i think this relates to my engine code???
vag-com scan is currently picking up no engine faults. the glow plug light on the dash board go off as it should.
i don't really know where to go from here? the advice of the faulty fuel pump was a shock as i would have thought the not starting is related to my turbo issues when i lost the power and barely got home?
i'm pretty desperate for some advise from someone that knows about diesels if anyone is kind enough to take the time so i can get back on the road. i'm worried as a faulty pump replacement would be hard to justify taking into account the mileage and age!
many thanks
many thanks
