My 03 had a intermittent starting issue I took the starter out. Took it apart cleaned, greased, put it back together.
To test it before I put it back in I placed it on the negative battery terminal to ground it. the cars ground was still attached to the battery.
I ran wires from the positive side. The cars positive wire was not attached to the battery.
When i touched the wire to the starter It worked great but smoke rose up from behind the battery
Now the car does not start.
I removed the battery and tray and took a look around I did not seen anything noticeable melted however I did not remove any the tape yet
I know its probably going to be bad but do you guys have any ideas?
Thank you
Thank you
