larrydk
Is this a DIY job? I've bled brake systems on my motorcycles in the past, but never in a car....any DIY picture tutorials from members here?
So when did VW change the sequence? It has always been Right Rear, Left Rear, Right Front, Left Front - farthest to nearest caliper to the master cylinder....open one bleed screw at a time in the order of FL FR RL RR...
2 or 3 generations ago. I think the intent is to avoid sending old fluid back through the ABS components and the long runs to the rear.So when did VW change the sequence?
Go figure. One would think that the ABS module, being right next to the master cylinder, would be the first thing to get flushed. Thanks for the update!2 or 3 generations ago. I think the intent is to avoid sending old fluid back through the ABS components and the long runs to the rear.
Great little write-up. I never removed that valve when I changed my clutch because I don't mind the feel of the system as is.The bleeder is under the air intake.
https://www.autoinstruct.com.au/man...mk7-golf/mk7-golf-clutch-delay-valve-removal/
