So I took the car to the gym and when I get out, this happens. My car recognizes the key, but it doesn't crank or start. When I pull the key out, the car still functions as if it's on... Is this a simple fix with just replacing an ignition switch?
It's possible the ignition switch is not bad and something else it.
Could be a broken wire, bad clutch pedal switch, starter, solenoid or such.
You have to use a test light (or meter) to check if power is coming from the ignition switch when you turn it.
Then check at the clutch switch, then the solenoid.
There is a heavy wire on the solenoid that goes inside the starter that has been know to corrode until it breaks.
A quick test, put the car in neutral and jump a test wire from the battery positive to the small terminal on the solenoid.
If the car cranks the starter is OK, it you just hear a click it could be the wire going into the starter broke.
