Old March 22nd, 2017, 06:34   #16
FLASH1970
yeah, I know the mess will come back. i couldn't get all the rust out of that hole. I plan on getting a different hood anyway. not worth it to cut new metal, weld it in... this is a temp fix to get by for now without having to look at a bunch of car acne. and I also didn't want to blend it onto the fenders because I plan on replacing the hood and front bumper cover and when I do, the blending will stick out.
Filled up yesterday... i can get used to the mileage! id get 280ish miles out of just over 12 gallons in my cobalt babying it the entire tank. i will say going from a 350hp cobalt to the golf makes passing in passing zones much harder though. :/
FLASH1970 is offline   Reply With Quote
Old April 11th, 2017, 12:45   #17
FLASH1970
replaced my mirrors a while ago. the old ones didnt heat and were a little discolored.
also, contacted the shop that did the clutch replacement, sent a picture of the receipt, invoice number, car info... asking them if they had any records on which clutch was put in because different clutches have different torque ratings. i wanted to know what i can do as far as upgrades without having to replace a clutch that's a couple years old. their response was..."That would have been a set with flywheel, either a Luk or Sachs. NEW no reman, probably a single mass." As far as I know, Luk and Sachs dont make a SMF clutch for the ALH. so that was no help.
Old April 18th, 2017, 10:42   #18
MattRabbit
I like seeing some of these semi-basketcase cars being given new life. They still can really look nice with some TLC and new bits. I bet when you replace the rusted panels, this car will look nearly new! Nice work so far!
2001 Golf GLS TDI w/Lux
1981 Rabbit Diesel
http://matt_lisa.home.sprynet.com/
MattRabbit is offline   Reply With Quote
Old April 18th, 2017, 17:48   #19
3L3M3NT
3L3M3NT's Avatar
It's great to see you keeping this car going. I sold the hood off my silver R that would have been perfect replacement for your rusted hood. Just keep at it and you'll have a car that looks good while getting right around 50 mpg
Sturgeon Bay, WI Cruise/GTG October 20th, 2018
Fix if you're using Chrome: Chrome fix
Firefox fix
RTDI Build Thread
3L3M3NT is offline   Reply With Quote
Old April 19th, 2017, 06:39   #20
FLASH1970
hopefully this car keeps going for a long time. I have a lead on a full black leather interior swap w/heated seats too from a member on here. hoping to get it this weekend then put it in. small hole in driver's seat from seat belt but oh well. patch it and call it good. I might also tear the cover off and add seat massagers to the driver seat. but it's from a jetta so the rear pillars, b pillars, headliner... wont be the same. so ill either redo them in black or just use spray dye. I wont have to look at those pillars while driving, so im thinking of going the easy route and use the spray dye. lol. headliner is stained from water around the sunroof (probably from being left open a few times, which ive also done, or clogged drains which I saw a receipt for cleaning out) and sagging around the sun visors so ill re-glue that before I dye it. and ill also have to clean and dye the rear door panels and put the leather insert in them because they are different. I also have to track down an exhaust leak still. and make sure I fixed all the oil leaks. I found a guy parting out a silver golf on CL who has a body panels I need but they won't respond. once the hatch is on ill tint the windows. I like my cars to be vampire friendly and it's waaaay to bright in there with no tint. im thinking I might want to the injectors too. I didn't see a receipt for those being changed at all so im thinking they might be a little tired. im getting around 42-43mpg with the car. 50mpg would be great, but at 80mph about a 1/3 of the time im in the car, wind resistance kills that.
this post got long so recap... lol.
hood, bumper, hatch, tint, interior swap to black leather, fix exhaust, double check to see if oil leaks are fixed, injector upgrade or perhaps tune (maybe both if clutch will handle it) and drive.
1970 beetle/02 WS6/97 TSi awd/ 92 TSi AWD/99 GSX/09 cobalt ss/92 dr650/01 softail.
I have a vagcom cable and can help out SE cheeseheads with a scan if need be.
Old April 22nd, 2017, 16:47   #21
FLASH1970
did some more work on the car. the old interior is grimy and worn out. so today I pulled it out. I bet if I left it gutted it'd get an extra 2-3 mpg. lol.. I'm going to be re-gluing the headliner that's sagging by the sun visors and spraying it black. i started spray dyeing the parts of the golf that the Jetta interior wont have. and tomorrow I'm going to get a black leather swap!
Old April 24th, 2017, 07:25   #22
FLASH1970
when your garage is full but car parts is life...
To all of us Dub-heads: nicklockard TDI 101 0 November 21st, 2007 16:56
V-Dub Waterama Shauger TDI Motorsports 7 July 7th, 2007 17:39
Luv my Dub Eric Cartman TDI 101 9 June 18th, 2007 08:24
New look for the dub Deezel dub Ontario 16 June 3rd, 2007 12:43
Just got my V to the Dub SoCal_John West Coast Canada/USA 8 April 11th, 2006 09:00
Page generated in 0.13984 seconds with 11 queries
[Output: 83.90 Kb. compressed to 73.20 Kb. by saving 10.71 Kb. (12.76%)]
