Old December 2nd, 2016, 21:03   #1
JohnnyCanuck.Comox
JohnnyCanuck.Comox's Avatar
Default 2nd VW, 1st Golf TDI
Hi everyone. I bought a 2004 Golf TDI in the rare (sarcasm) colour of grey. I'm the 2nd owner, the original owner is from Victoria and it spent it's life there. It has 170,890 kms on it, timing belt was done recently and just had rotors/pads done, and regular maintenance at VW in Victoria for it's life. Also has new tires and is in great shape inside and out aside from a couple of little dings. It had two claims from being rear-ended, one was $360 and one was $1940.
Plans for it: nothing big for now, get some window tinting on rear and back windows, maybe finds some different wheels, polish the headlights and fix the satellite radio mount he slapped on the dash.
A pic of my 73 super beetle, I bought a brand new short block from vw for $800 in 1984.
2004 VW Golf TDI GLS 5 spd.
1997 Subaru Forester JDM rhd SF5 http://www.subaruforester.org/vbulle...rester-543449/
2011 Subaru Forester Limited
JohnnyCanuck.Comox is offline   Reply With Quote
Old December 3rd, 2016, 05:14   #2
red16vdub
red16vdub's Avatar
Nice looking golf, color is reflex silver btw not gray.
Mk1 Gti /scIROCco 16v /A6 quattro sport / Mk4 TDI JSW 5spd
17/56 turbo, RC ASV-5+ @ 28psi, 3 Bar Map, 11mm IP, PD Lift Pump, R520's, McNally boost/egt, Euro FIS full screen Cluster, PD 150 Intake/racepipe, PD 150 plastic T.I.P + R32 maf air mods, Kerma 2.5" Fmic, Kerma 3"T-B exhaust/resonator/ Aero turbine muffler, SBC stage 3 Endurance, GLi brakes F/R , GLi axles, H&R Bilstein sports cup kit.
red16vdub is offline   Reply With Quote
Old December 3rd, 2016, 07:20   #3
JohnnyCanuck.Comox
thanks, good to know.
Old December 5th, 2016, 11:29   #4
MattRabbit
Nice car! Looks perfect to me, as-is. The wiring out of the dash is a bit strange, but that's an easy fix. I also would find some nice alloy wheels for it. Otherwise, just maintain and drive!
2001 Golf GLS TDI w/Lux
1981 Rabbit Diesel
http://matt_lisa.home.sprynet.com/
MattRabbit is offline   Reply With Quote
Old December 6th, 2016, 15:11   #5
JohnnyCanuck.Comox
I've fixed the satellite wiring, I got the black mounting piece off that the po made for the satellite radio. Thankfully he left the oem piece that fits in there so it looks better. And I'm on the prowl for some alloy rims.
Old December 15th, 2016, 07:20   #6
theprimer
Hey that's a good looking ride. I hope you got it for a decent price for the mileage on the clock
theprimer is offline   Reply With Quote
Old December 15th, 2016, 14:18   #7
JohnnyCanuck.Comox
I paid $6,700CAD (just over $5k usd), after looking for 1/2 year it was the lowest mileage TDI I could find that was well looked after AND had 5 spd. There were a couple of ALH versions that I liked that had around the 250k or so for mileage, but they were either beat up a bit, filthy, not looked after, had auto, etc.
Old December 16th, 2016, 09:14   #8
leon10tagg
leon10tagg's Avatar
You'd be hard press to find a golf as clean as yours in NI. One of the main issues here is corrosion due to salting of the roads during the winter to break up snow and ice.
01 Golf Tdi, FMIC, CR1756 turbo, PD intake, Newman cam, EGR delete, BV, modified intake, 80mm MAF, turbo back 2.5" Milltek, 11mm IP, R520s, 3bar MAP, TD tuning box, PD130 O/C,Spax adj's, Eibach A/R bars, powerflex bushings, 312mm discs, top and bottom strut braces
05 & 04 Passat AWX, 98 Impreza turbo, 97 A4 1.8T sport
http://forums.tdiclub.com/showthread.php?t=298788
leon10tagg is offline   Reply With Quote
Old December 18th, 2016, 11:49   #9
JohnnyCanuck.Comox
I took off the plastic engine cover, insulation was disintegrated and that cover with the fake intake runners looks cheesy.
Jumpy acceleration on 1st and 2nd gear - VW Golf TDI automatic 2.0L FutureGolfTDI General Automotive 0 August 2nd, 2015 14:52
2013 Golf TDI Hissing sound when gearing through 1st and 2nd macthedog VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 5 July 24th, 2013 04:57
Sharp Turbo Sound When shifting from 1st-2nd then 2nd-3rd. srpsandro VW MKIV-A4 TDIs (VE and PD) 6 September 18th, 2012 20:35
MK4 ALH Golf 5spd hard to shift 1st - 2nd Diesel Mania_26 TDI 101 6 February 9th, 2011 12:39
DSG Stutter 1st to 2nd and 2nd to 3rd. DMF? Corbin VW MKV-A5 Golf/Jettas 11 February 10th, 2009 19:46
Page generated in 0.09625 seconds with 11 queries
[Output: 93.55 Kb. compressed to 80.01 Kb. by saving 13.54 Kb. (14.47%)]
