Old October 3rd, 2016, 13:40   #16
snakeye
snakeye's Avatar
I the rear calipers, how did you press the rear seal back in (the ones that go under the handbrake lever)?
Great work btw!!
snakeye is offline   Reply With Quote
Old October 3rd, 2016, 16:32   #17
Louis_TDI
Louis_TDI's Avatar
You mean the ones on the outside? If so I pushed them by hand they are not super tight but you have to make sure the the caliber is clean and they go in well.
Cheers Louis
My Old Friend 2003 Golf Rebuild Thread
Louis_TDI is offline   Reply With Quote
Old October 9th, 2016, 08:43   #18
snakeye
snakeye's Avatar
Ah ok thanks! I guess I'll have to do more scraping next time. The corrosion buildup around that area is crazy!
Old October 9th, 2016, 09:31   #19
aja8888
aja8888's Avatar
TDI(s): Out of TDI's
Fuel Economy: About as good as it gets!
Louis, did you use new seals for the e-brake shafts? If so, where did you source them from?
Thanks, Tony
Originally Posted by Big Mike View Post
........"Everybody has a plan until they get punched in the face." -- philosopher Mike Tyson.
aja8888 is offline   Reply With Quote
Old October 9th, 2016, 16:31   #20
Louis_TDI
Louis_TDI's Avatar
Yes it is! Thats why I painted the calipers I wanted to see if that would help stop the corrosion.
Thanks, Tony
Yes all new seals ordered them on eBay from
BiggRed
The quality was very good apart from the blender caps but still had the OEM ones. All and all the cost was 60$ Canadian.
Its the kit on the top of the picture
Worth metionning the plier I used were from Princes Auto the only ones I could find long but small enough
Cheers Louis
Old October 10th, 2016, 06:27   #21
Louis_TDI
Louis_TDI's Avatar
Oh And the best part of the calliper kit It arrived in 3 days from the UK. Crazy fast takes us longer to get stuff from within the country.
Cheers Louis
Old October 10th, 2016, 09:42   #22
aja8888
aja8888's Avatar
Thanks for the tip. I ordered rebuild parts for my starter (brush box, bushings, solenoid) and they came from Ireland in less than a week.
Old October 11th, 2016, 18:03   #23
Louis_TDI
Louis_TDI's Avatar
Yeah did that last year. Just in time too the brushes most likely only had a couple of weeks left of starts. The coper wire on the brushes was about to touch the router.
Cheers Louis
Old October 13th, 2016, 20:42   #24
GIDDY_UP_GO
Fuel Economy: 39mpg (But I drive 80mph alot!)
Amazing! Keep up the good work! Wish I had your energy and ambition!
2004 Jetta TDI 183k mi
2010 Jetta TDI 155k mi (Fix Completed 12/17)
2015 Jetta TDI 40K mi (Did the buyback on 2/17)
2015 Golf SportWagen 4000 mi
THIS WILL MAKE YOU CRY!
GIDDY_UP_GO is offline   Reply With Quote
Old October 26th, 2016, 16:16   #25
Louis_TDI
Louis_TDI's Avatar
Was at my friends garage to bleed the brakes the other day and so happy with what it looks like underneath I had to take some pictures.
Also have finished pictures of the marineco plug for the frost heater the fender isn't painted yet but keeping that for next summer. Although I do have one that is in good shape but I didn't want to put a big hole in it.
Cheers Louis
Old November 21st, 2016, 02:59   #26
Louis_TDI
Louis_TDI's Avatar
Did a wheel alignment last week end used the string method worked well know the steering wheel is nice and straight. Also used metal plates grease and a tiles to make the front wheels turn freely.
Here's one of my little tricks to prepare for winter I always put anti seize and electrical tape over my tie rod and it prevents corrosion. This is after two winters.
Cheers Louis
Old November 21st, 2016, 03:05   #27
Louis_TDI
Louis_TDI's Avatar
Snow was in the forecast so put my brand new Nokian Hakkappelita 8 studded winter tires on can't wait to try them. They are on 15 inch Corrado wheels I got for 100$. Also put some mud flaps in this case it's snow flaps. They are actually cutting boards from Ikea will see how those last.
Cheers Louis
Old December 2nd, 2016, 06:53   #28
csstevej
Need to do the ASR mod. Nothing short of feet of snow will stop that car with studs and ASR .
I have the same same setup on my daughters 03 nb, ASR , studded tires plus I gave her car a 2" lift kit...... Pretty impressive in the snow.
Very nice rebuild, I need to do that to mine, 01 golf 370,xxx miles in snow belt/salt country.
What is the string method?
2001 golf auto to 5 speed manual swap,G60/VR6 clutch setup,coolant migration mod.
csstevej is offline   Reply With Quote
Old December 16th, 2016, 16:43   #29
Louis_TDI
Louis_TDI's Avatar
Thanks for the kind works
Ill have to look in to the ASR mod I don't know what that is. I had taught of a 1 or 2 inch lift but I do like the stock ride hight, but I can just imagine how more impressive it would be for the snow.
The string method of alignning a car basally consist of building a square box around the car so you can take precise mesurement from front to back of there wheel to compare toe in or toe out. There are several ways of doing this some much more precise like on race cars witch are on scales and have marked centre lines on the car as a reference point for the alignment jig to a more crude method like I did.
Cheers Louis
Old December 19th, 2016, 21:52   #30
MartinRodri
TDI(s): TDI SE
Excellent job. Keep it up.
MartinRodri is offline   Reply With Quote
2003 Beetle TDI 5 speed rebuild kwasnr New Beetle TDI Picture Gallery 14 May 2nd, 2016 16:06
2003 jetta tdi turbo rebuild. moose187 VW MKIV-A4 TDIs (VE and PD) 7 October 10th, 2015 20:08
Friend driving 9hr to buy a 2003 TDI wagen in Va Aquaticmind TDI 101 3 April 26th, 2013 10:05
WTB: Another Golf/Jetta TDI '00-'02 for a friend TDIMontreal TDI Cars for Sale/Wanted 0 December 25th, 2005 14:40
2003 Golf GL TDI is my new best friend! newflyer22 Golf TDI Picture Gallery 2 October 13th, 2002 21:31
Page generated in 0.17048 seconds with 11 queries
[Output: 132.56 Kb. compressed to 110.64 Kb. by saving 21.92 Kb. (16.54%)]
