nikolay_ss
If you change your nozzles with bigger, for example from stock 110ps(0.205) to 0.216 you should decrease your IQ a little. Probably if you had a tune for smaller nozzles and you are now at 6mg with 0.216, it's even more than 6mg, you should check the pump voltage at 3rd column on 001 channel. For best results you need to remap your pump voltage map.
For example on my ALH I'm with dlc1019 and 11mm pump, at neutral my pump is working at 1.35V and I have no vibrations and nothing, just working perfect. So you need to decrease your IQ until there are some vibrates and then increase it a little until they stop. But as I said for perfect results, you need remap. Also it needs some SOI corrections when changing nozzles.
