Diesel_Man
I finally got some new tires and wheels.
I would post a before and after pic, but I do not know how.
Diesel Man
Diesel Man
Diesel Man
Thanks.
I was looking at that and tried, but the file size was too big. I was able to crop it a bit and get the pics uploaded
Waddya tink?????
Before
After
Thanks BobnOH It took a litttle bit to figure out some things, but I got it
I didn’t do nuthin’, but got a thumbs up from a fellow mk4 tdi owner.. are there tdiclub stickers or badges?
I'd be looking at the trunk, see if the body part is caved in, looks like it might be. That's expensive to fix and have it not leak. The front doesn't look too bad.Well, friday the 2nd was a sad day. Not really what I did but what someone did to me...
I was stopped at a red light when the car BEHIND me was rear ended, causing him to rear end me, which caused me to rear end the car in front of me. 4 cars involved, I was 2nd in line. Nobody was hurt so that was great.
The damage is worse than it looks from the pics. I'm sure it'll be totaled. Does seem fixable though. No idea if i'll buy it back and fix it, buy it back and part it out, or just let it go. I have my truck to drive and I'm thankful for having a second vehicle. It's a Ridgeline so it's a good dd.
Really sucks. My dad has an 04 Golf and we were just talking the other day about how the only thing that can really stop these cars is rust or a wreck.
Yep, on the driver side, where the tail light sits, that area/metal is pushed in a lot.I'd be looking at the trunk, see if the body part is caved in, looks like it might be. That's expensive to fix and have it not leak. The front doesn't look too bad.
Ouch, sorry for your loss man... If you decide to fix it, I'm sure lots of folks in the forums have parts to help you get it on the road again.Yep, on the driver side, where the tail light sits, that area/metal is pushed in a lot.
Based on the descriptions in your signature, the parts are worth much more than the Jetta. You should swap everything over to another Mk4 chassis.Well, Friday the 2nd was a sad day. Not really what I did but what someone did to me...
Buy back should be real cheap, I totally agree.Based on the descriptions in your signature, the parts are worth much more than the Jetta. You should swap everything over to another Mk4 chassis.
Appreciate that, I agree, this would be the place to look for parts and help.Ouch, sorry for your loss man... If you decide to fix it, I'm sure lots of folks in the forums have parts to help you get it on the road again.
Good idea that I'm going seriously consider.Based on the descriptions in your signature, the parts are worth much more than the Jetta. You should swap everything over to another Mk4 chassis.
Also true. Not sure what I'll end up doing but gonna have to look at all options.IMO, buy back will be less than just the engine is worth.
cheers,
Douglas
T
After
I attempted to explain that concept to my wife back when DieselGate began... I knew the moment my wife called me (this February) to tell me she'd been hit in her '06 MkV that it would be totaled... It was. I sat on the carcass for months debating the next best move with a chassis we'd owned since it was brand new. Finally gave it to the insurance company in return for a check... Copart got a really great engine and tranny out of that deal!My dad has an 04 Golf and we were just talking the other day about how the only thing that can really stop these cars is rust or a wreck.
If it's totaled I'm pretty sure I'll buy it back. Definitely agree that there are too many good parts to let go to waste.Oh no! Glad you're ok, and also glad that most of your car's value was in the engine, which looks to be fine. If you were in California I'd make you an offer on that car right now.... definitely voting to buy it back, don't trash that good stuff! Find a stock mkiV (maybe even upgrade to a wagon if that's appealing to you) and move it all over!
What's up man hope all is well!I'd been chasing an oil leak at the EGR valve on my ALH.
I have a new EGR to install, but wanted to reduce the amount of oil going through the intake.
I installed an agricultural strainer as a crankcase breather trap, but found that very little was actually coming out of the crankcase to start with.
Since the turbo is the only other source of intake oil, so I took a second look at a turbo that I'd saved from a parts car.
Finding around 1/16" of axial play on the shaft, instead of the 1-3 thousandths that seem to be the acceptable range.
I dropped it off at DFIS PDX who cleaned and rebuilt it in a week for ~$560, so now I just have to drop the old one and install the new.
