Old July 14th, 2017, 20:00   #166
A-man930
very interested to see how the heavy flywheel works out.
A-man930 is offline   Reply With Quote
Old July 15th, 2017, 20:06   #167
evguy1
Originally Posted by Motohead1 View Post
Turns out one of the 6 adapter bolts backed out and the washer and lock washer were randomly making a ding noise.
Be sure there is RED locktight on those 6 bolts. A couple of people have had them back out......including me. Red locktight is a diesel swapers friend.
Coming from a business doing electric vehicles conversions for 27 years I just never have to worry about vibration so the diesel swaps have been a real introduction to the problems of the ICE.
evguy1 is offline   Reply With Quote
Old July 16th, 2017, 09:25   #168
Motohead1
Good to know. I have red on the crank spacer bolts and flywheel bolts. I was always kinda used blue or green locktight on aluminum as the softer stuff would sometimes take the threads out with red. These went in dry. They will get something going back in this time though.
Motohead1 is offline   Reply With Quote
Old July 23rd, 2017, 16:34   #169
Motohead1
So finally got the truck back together. Replaced all the ball joints and bushings, shocks, steering rack and pulled my 240K mile trans and put in a 150K mile spare NV3500. Also lock tight on every adapter bolt. Had one that was loose making me think it was a transmission noise as it was rubbing the back of the flywheel and all others were snug but not as tight as when I put them in. Lock tight should fix all that now.
The big upgrade though was the 40lbs (more like 42) flywheel. stock4.0 jeep is 27lbs
The rattling intermediate shaft in the NV3500 is definitely quieter. The from idle inertia helps too not that it was lacking before. But now its smooth no matter what gear or throttle input your giving. Its a must buy IMHO.
Tires and alignment is next.
Old July 24th, 2017, 23:43   #170
xjjeeper
xjjeeper's Avatar
Great news about the flywheel! I'll deffinatly grab one when I'm at that point with my xj alh swap
1999.5 alh soon to be installed in a 1999 jeep xj
xjjeeper is offline   Reply With Quote
Old July 27th, 2017, 17:26   #171
Motohead1
Wheels tires and alignment. I went with a deal I found on a 265/70 r17 Goodyear Authority used. Measures 31.7 inches. Anything bigger than that would rub for sure.
I need to do a boost leak test as today I got overboost code. Kinda worried me at first as it wasent making much part throttle boost suddenly on the highway and egts went up. It cleared up after a restart. Ill have to do some research on causes for that.
Old July 27th, 2017, 18:30   #172
All Stock
TDI(s): AHU
Are you attributing the quiet NV3500 idler rattle (marbles in a can sound) to the flywheel or is it a result of the different trans?
Is the surface on the centerforce FW curved as the oem one is supposedly?
Which clutch are you using...or how much is it rated for?
Jeep Wrangler TDI Hybrid...
All Stock is offline   Reply With Quote
Old July 27th, 2017, 18:39   #173
Motohead1
Flywheel for sure made the difference. My original trans is still good and measured the same lash as the newer one.
Not sure on the curve? looked like stock except the back is completely solid.
Clutch is a stock $46 rock auto clutch for a 2001 4.0 jeep.
Old August 9th, 2017, 19:58   #174
Motohead1
So this week I am working on getting cruise to work. First I wired up a 5pin 40amp relay to act as my TDi brake switch. Nice to finally have that 1400rpm throttle cut out after startup finally fixed. Next I attempted to grab the Dodge VSS signal coming off the ring gear and feed pin 20/121. But VCDS said no signal. This didnt make sense to me as Reddoks Jeep swap worked this way.
See here is the VSS diagram. Looking at it now I tapped into the-Neg side. Maybe it needs to be on the+ side?
Old August 9th, 2017, 20:04   #175
Reddok
Reddok's Avatar
Fuel Economy: Jetta: 40.8 avg, 47.1 best. Jeep: 30 avg.
Pretty sure I tapped the positive side.
2000 Jetta 01M: Ventectomy, Snowscreen removed, Injection timing advanced, EGR dialed back.
2002 Jeep Liberty TDI Project: 2002 ALH, 1749VA, NSG-370 6-spd, PP764's on T4's, 11mm pump, PD150 intake, custom tune, Cummins lift pump, 2.8 CRD intercooler, 2.5" DP/exhaust with Magnaflow cat and Walker Quietflow muffler.
Reddok is offline   Reply With Quote
Old August 9th, 2017, 20:10   #176
Motohead1
Thats got to be it. I dont see any other reason to not get some kind of signal.
Old August 10th, 2017, 14:52   #177
Motohead1
Well tapped the positive side and still nothing . I might have to get a dakota digital box and vampire the speed signal coming out of the ABS unit white/orange wire. Still would like to know why its not working though.
Old August 10th, 2017, 15:35   #178
jimbote
jimbote's Avatar
what about the white/orange wire labeled vehicle speed signal ? that could be the output to the speedo
jimbote is offline   Reply With Quote
Old August 10th, 2017, 16:14   #179
\/\/0J0
\/\/0J0's Avatar
Fuel Economy: At least 2x that of my TJ
I think you might be onto something there, Jim lol
Sent from my mobile look-at device
I miss my TDi
"Those willing to sacrifice Liberty for Security deserve neither" -Ben Franklin
\/\/0J0 is offline   Reply With Quote
Old August 10th, 2017, 16:21   #180
jimbote
jimbote's Avatar
yeah, i'm captain obvious... i studied the diagram and posted a response before i read moto's reply
2000 dodge dakota quad cab 4x4 with tdi jetmoto3 Private TDI Items for Sale/Wanted 6 October 26th, 2015 11:36
FS: Dodge Dakota 2.5L Bellhousing Kriesel Private TDI Items for Sale/Wanted 1 April 12th, 2010 10:05
WTT: My 99 Dodge Dakota for a TDI. Smola67 TDI Cars for Sale/Wanted 1 June 13th, 2007 02:25
1999 Dodge Ram 3500 Quad Cab SLT, Cummins Diesel Dieselworld TDI Cars for Sale/Wanted 2 March 23rd, 2005 19:31
1998 Dodge Ram 2500 24v Cummins Turbo Diesel Quad Dieselworld TDI Cars for Sale/Wanted 10 March 7th, 2005 10:22
Page generated in 0.21454 seconds with 13 queries
[Output: 130.60 Kb. compressed to 109.50 Kb. by saving 21.10 Kb. (16.16%)]
