Just did a timing belt job. Not to bad of a job. Couple of things that annoyed me.
1. The dieselgeek crank lock is worthless, maybe mine was fabed incorrectly. Wouldnt hold the crank as designed. And why do you need to place a screwdriver in the flywheel if you have this tool?
2. I used an allen key wrench for the valve cover bolts, no problem there.
3. The damm cover that accesses the pollen filter is very brittle............any place to get one replaced?
4. Water pump install was pain, thank god it didnt leak.......no do over here.
5. The Vag Com thing is way cool. Set my pump up with it, very easy I might add.
6. I dont like the tensioner design at all.......why didnt the make a manual tensioner for this motor?
7. My intake is probably caked, I looked at the EGR valve and the deposits were pretty thick. I get about 54 MPG with no acceleration issues so Im going to wait cleaning it for now.
By the way, I was shakled to doing this job myself. The local stealership in Evansville, IN kindly left tools in my doors on left loose drain plugs in place after oil changes.
These idiots work on Porches, MB and Bmers go figure.
I passed on them doing this job. What are guys getting to do this job? $$$
Thanks for all your help
