Stromaluski
- Joined
- Oct 23, 2013
- Location
- Greenville, SC
- TDI
- '67 Deluxe Bus, '80 Rabbit Truck, '92 Corrado, '10 Cup Edition
I'm just getting my Jetta back together after about 2 months of being apart. Prior to taking the car apart, it was stock aside from DLC1019 injectors, a malone stage 3 tune, and I put an 11mm pump head into the stock injection pump. It was running great, but of course, looking for more power.
Decided to convert to a VNT-17 turbo off of a BHW Passat. So changed to the BHW turbo/exhaust manifold. The head was rebuilt by Frank06. While it was apart, I had DBW clean/check the injectors, which they said were in great shape. Picked up a stage 2 cam/lifters at the same time. Put a 2.9bar MAP sensor in the ECU with a pre-liminary stage 5 tune from Malone. I don't yet have a downpipe on it (since NOBODY makes one for a BHW turbo on a mk3). I'm going to take it to an exhaust shop to have one made once i could actually drive it on/off a trailer.
In any case, I cranked it a bit with the injection pump unplugged to get oil up to the turbo. Plugged everything in and tried to start bleeding all the air from the lines. Took some cranking, but got it to start up and half way idle/rev up/etc. It had decent throttle response (important). Definitely needing more adjusting and more bleeding to get remaining air out.
Since it wasn't terribly easy to start, I adjusted the pump all the way toward the back of the car and it would start up great, but immediatly start to run away. Hammer modded the QA toward the passenger side of the car and it would run, but have a miss at idle and have zero throttle response. Tried adjusting the QA with the car running and the only options are to have the IQ down around 0.5 where it will miss at idle or it will start to run away. There's no in between.
I asked Owain at Malone for advice and his thought was an injection pump issue of some sort. I don't have an extra AHU pump and am really hesitant to simply pull my pump off and send it off to be rebuilt without knowing for sure what is going on. It's a lot of money to spend on something that may or may not fix the issue.
I checked block 19 and the min/max voltages are 0.75v/4.45v, which is within spec from what I can tell, which makes the think the QA is fine. Visually inspected the wiring to the pump (large and small plugs) and they both look ok. The collet did cause a little bit of chafing on the wire to the shut-off solenoid, but it didn't seem excessive (the collet was removed a while ago). I have not yet checked them with an ohm meter.
Not sure if it is worth mentioning or not, but I did replace the serpentine belt tensioner while everything was apart with one from IDParts. The replacement is larger than the factory tensioner actually touches the wiring to the solenoid underneath the pump head (cold start injector?).
https://www.idparts.com/serpentine-belt-tensioner-a3b4-p-677.html
So... Any ideas?
So... Any ideas?
