Old July 25th, 2017, 18:07   #1
Cptcrnch
Default Cptcrnchmobile 2.0 - 2004 Jetta wagon
After deciding to keep my 2014 Golf I went and decided to get married later this year. Being able to pay cash for my wedding made the buyback look real good but I wanted to stay in the TDI family. I started the search for another TDI and found my next ride here in the forum!
Came across this great little 2004 Jetta wagon that just had a 5spd swap, TB, and a bunch of other PM work performed. Car is rust free too! A good thorough detailing inside and out will have it looking like a champ. It has the typical Mkiv issues (headliner, seat bolsters, etc) and I plan on a suspension refresh later this year (it rides okay now and steering is tight but rougher roads reveal it's time for a refresh). This is my first Mkiv and I'm looking forward to getting to know this motor and performing as much work on the car as I can.
Cptcrnch is offline   Reply With Quote
Old July 27th, 2017, 12:59   #2
Electrodynamic
Electrodynamic's Avatar
Fuel Economy: 47 mpg
Cool purchase.
The upside down picture reminds me of those cartoons where they would dig a deep hole and pop up upside down in another country. Haha.
Current car:
Previous car:
Electrodynamic is offline   Reply With Quote
Old August 6th, 2017, 17:18   #3
Cptcrnch
Polished out the headlights with great results. Not perfect but 100x better. Last week I washed, clayed, and waxed the car and it cleaned up great. New tires last week as well. Later this week the carpets will get a good shampoo and the leather will get a deep clean and condition
Old August 10th, 2017, 20:48   #4
Cptcrnch
Spoke with Owain at Malone Tuning and the guys at New German Performance today. Between weddings, anniversary parties, and OT at work, a lot of stuff is going to be done next month. The plan is a Malone Stage 1.5 tune with dynamic EGR once I can do the logging in VCDS. The car will also be headed to NGP for a suspension and steering refresh with a Vogtland Junior Cup kit. It should remove the fender gap while still keeping it smooth and comfortable for highway cruising but still let me have some fun every once in a while. I also plan to do the 240k maintenance a bit early so I don't have to be out there in the dead of winter doing it.
As the car doesn't have a belly pan or side engine covers it's getting the Diesel Geek Panzer Plate and Full Metal Jacket treatment. The front fender liners are also pretty beat up so it's getting new liners and foam inserts. Since the roads in my area are crap and we use a ton of salt in the winter getting this squared away before the winter is high on the priority list to protect the motor and all the wiring.
That will probably be it until the start of spring and tax season. Then it's a 2.5" stainless steel turbo back exhaust and new wheels. What's on the car now is the OEM stuff that has 230k+ miles on it and it's rough. Before the hot summer temps next year I plan to do a full coolant system refresh with new radiator, intercooler, piping, hoses, etc.
And here I promised my fiancée I wouldn't put a ton of time and money into the car. Lol
Old August 11th, 2017, 15:16   #5
h4vok
h4vok's Avatar
Fuel Economy: 35 to 50
What did you use on the lens to make it look so good? I have seen many method to this, but I am curious what you did?
DLC520, Mufflerectomy, tuned, more linked below
My car thread
h4vok is offline   Reply With Quote
Old August 11th, 2017, 15:58   #6
Nice to see someone taking care of another Jetta Wagon. Some people skip the foam inserts in the fenders, they can trap moisture. I have mine in place and haven't had a problem, but if I had to buy new ones I'd probably skip it. Also look and see if the pinch welds on the rockers are bent over from someone jacking up the car incorrectly. Happens a lot, and rust can migrate into the rocker panels from the bent welds. POR-15 is your friend for that kind of damage.
And if it hasn't been replaced check the cam for wear.
Old August 11th, 2017, 16:20   #7
Cptcrnch
I just used the Adams Polishes headlight restoration kit and followed the directions.
http://adamspolishes.com/shop/kits/4...ation-kit.html
Old August 11th, 2017, 16:34   #8
Cptcrnch
Thanks for the valuable insight about the foam inserts. I may put some POR-15 in that area as a preventive measure even if there's no rust as the liners will already be off and it'll be easy to access. I'll give the pinch welds a good look tomorrow!
The previous owner just had Mike at M&M Auto Cycle do the TB and the 5spd swap. Mike went over all the mechanics and the cam is good shape as is the turbo. For 235k miles the car is still in great shape.
Old August 15th, 2017, 19:21   #9
Cptcrnch
Got the windows tinted yesterday. I actually like the wheels on the car right now. I'm going to wait until the winter when the snow wheels/tires go on and have them refinished and repainted.
Old August 15th, 2017, 19:33   #10
Cptcrnch
Took the EGR valve out and gave it a good cleaning. Mainly just gummy tarry soot that came off real easy. What I could see of the intake wasn't bad - It could use a cleaning for sure but didn't look super blocked. I'll probably put off removing and cleaning the intake until next spring. As already stated above a Malone 1.5 tune with Dynamic EGR is coming soon so one good cleaning should be good for the remaining life of the car.
Old August 18th, 2017, 19:10   #11
Cptcrnch
So a day after cleaning the egr valve the car threw a CEL. I rechecked all my work and everything looks good. My Vagcom cable should be here tomorrow and I'll be able to scan it. It should be related to either the egr valve or the air intake since I pulled that to check the snow screen.
Also ordered a new Pioneer Bluetooth only head unit to replace the OEM cassette/cd player. Should be able to install it next Friday.
Old August 20th, 2017, 13:52   #12
Cptcrnch
Scanned the car and found a bunch of codes for the auto trans that I expected since it had the swap done. It also had a bunch of codes from the no start I had from when I had to unplug the ECU after a washing the car.
The car is still throwing a P3003 and P3005 for a High and Low output preheating of coolant but no CEL or MIL.. I've had no drivability issues so I'll drive the car to work and back (100mi round trip) and scan again and see if it cleared. It might be due to transmission swap, always be present, and not be any issue.
Old August 23rd, 2017, 14:05   #13
Cptcrnch
Stereo got a much needed upgrade today. Really happy with the quality of everything. Connecting the radio harness to the car harness adaptor was super easy and the kit I bought to retain the steeriing wheel controls works flawlessly. I was able to hide the wires for the microphone and USB so it looks relatively factory.
I still have the trim pieces off as I want to try using Back to Black Trim Restorer on the sticky soft touch plastic. If it works well on that small piece I'll hit all the soft touch pieces.
Old August 25th, 2017, 14:06   #14
Cptcrnch
Since PA doesn't require front front plates I had no need for the license plate frame. Sadly the frame was mounted with six screws! Two of the holes were the size of quarters. Ugh - I don't have the time to go to salvage yard and trying to find one that hasn't been drilled. I'd rather have a clean front end but this is a good solution for the time being. I had a custom Euro plate made. I wanted something that looked random and wasn't stupid or childish. I went with the date of my upcoming wedding - that way I can't forget my anniversary lol.
Old August 27th, 2017, 07:52   #15
GIDDY_UP_GO
Fuel Economy: 39mpg (But I drive 80mph alot!)
You Sir, will have a long and happy marriage!
2010 Jetta 160K mi (Fix Completed 12/17)
2013 Beetle Convertible 70K mi
2015 Jetta TDI 40K mi (Did the buyback on 2/17)
2015 Golf SportWagen 12K mi
THIS WILL MAKE YOU CRY!
GIDDY_UP_GO is offline   Reply With Quote
2004 jetta wagon Boojop TDI Cars for Sale/Wanted 6 April 3rd, 2011 17:40
WTB: 2004 Jetta Wagon PD TDI w/ 5spd, or 2001-2003 TDI wagon barooo TDI Cars for Sale/Wanted 11 January 14th, 2010 21:33
Trade: my 2004 Jetta GLS for your 2004+ Passat 1.8t wagon? zanzabar TDI Cars for Sale/Wanted 0 June 30th, 2008 10:32
2004 Jetta Wagon MedicineMan VW MKIII-A3/B4 TDIs 2 August 26th, 2005 01:05
Page generated in 0.16948 seconds with 11 queries
[Output: 131.78 Kb. compressed to 110.06 Kb. by saving 21.72 Kb. (16.48%)]
