Old September 10th, 2019, 15:09   #1
LMJ
TDI(s): 2000 VW Golf
Default 2-Yr Battery?
Interstate asked me if I wanted the 2-yr or 6-yr battery. I chose the 6, like last time. It lasted exactly 6 years. There's no indication on the new battery of it expected life. Do battery manufacturers actually make of 2-yr battery and how do I determine now that mine is a 6.
Upgrades: Rocket Chip Stage II, Full Metal Jacket Skid Plate, Bosal Euro Hitch, aluminum capped shifter and new boot, 2-cup rear center console, replaced seats.
LMJ is offline   Reply With Quote
Old September 10th, 2019, 15:57   #2
Mongler98
eh, yes and no.
cheep vs expensive lead acid wet batteries last about the same, give or take. there are threads opon threads about this going either way, its a can of worms your diving into if you want to know more, i suggest you go to thecandleforums.com and read up on batteries and how they need to be charged and discharged,
most batteries are actually rated in amp hours and given a life expectancy of cycles. car batteries are usually cut in half as they dont get discharged down to 60%, they keep getting topped off all the time with amps. in general you can get a 1 year battery to last 5 years, and i can easily kill a 6 year battery in one year, its all about what your use is and in a car its about where you live and what the car was designed for, diesels in cold areas, batteries dont last as long.
again, rabit hole here,
in b4 massive debate thread that gets derailed
Old September 10th, 2019, 17:14   #3
LMJ
Originally Posted by Mongler98 View Post
eh, yes and no.
I'm not looking to do a research project here, simply want to know if manufacturers (in my case Interstate), makes a "2-yr" car battery cause it sounded like a scam when the salesperson asked if that's what I wanted.
Here's what happened. My car battery was dead monday morning, so I drive the truck to work. Stopped off at Interstate on the way home to get a new one. Figured they know what size I needed. Sent me home with the wrong one. Today I looked up the recommended size on Interstate website and wrote down the price. On the way home I returned the small one I bought yesterday and bought the correct one. While there, Interstate quoted me a price that was more than listed on the website. When she quoted me a price she asked if I wanted the "2-yr" or 6-yr" battery. Is there such a thing as "2-yr battery" being offered by Interstate (or did she just make it up).
Old September 10th, 2019, 20:34   #4
Lightflyer1
Lightflyer1's Avatar
There probably is as they are rated for any number of years including lifetime. But a cheap short rated battery can be made to last quite a while if taken care of properly and you can kill a lifetime battery pretty quickly by neglecting it. Just what Mongler98 told you above. I have bought used cheap short rated batteries and had them last for years as well. My antique car battery is over 15 years old, but I take excellent care of it.
Old September 11th, 2019, 02:54   #5
Mongler98
So the answer your looking for, yes. There is a 2 year and a 6 year and warranties and lots of bs you will get from places like interstate. Avoid them and buy your battery at costco or walmart.
The only 3 things you actually need to care about are size, cca, and date of manufacturing. A battery make in 2016 has been sitting around and will last less for you. Dont bother with things like, gold, silver, platinum, or 2 year or 4 year or extended warranty. These are all just marketing bs. Yea there techincally is a difference in the battery but its come down to the difference in testing at the manufacturer, not internal construction, kinda!
Just go buy the best bang for your buck. Make sure that of your car calls for AGM, you get AGM, and if it's not clearly states in your owners manual then default to the lead wet acid type.
Old September 11th, 2019, 05:00   #6
scooperhsd
On a TDI, don't even worry about CCA - you want AMP HRs. Get the battery size as recommended by VW and you will be fine. Most of them take either a Group 94R (H7) or Group 48 (H6). The newer the better. I had a place want to sell me an H5 because "it had the CCA rating (640) called for by VW". I straightened them out pronto.
2000 Red NB TDI, 370,000+ miles
Now 5 speed manual and onto 500,000 miles + !
2015 Golf TDI SE DSG
scooperhsd is online now   Reply With Quote
Old September 11th, 2019, 06:20   #7
Dannyboy
Dannyboy's Avatar
Fuel Economy: All good on the motion lotion
Excatly the opposite if you live in a cold climate.
However he is in temperate climate so slap anything in there that meets the spec.
Dannyboy is offline   Reply With Quote
Old September 11th, 2019, 06:25   #8
Mongler98
While that's mostly true, you need to understand that CCA and amp hours are not directly related. You can get a 100 amp hour battery but it only has a rating of 450 CCA while you can get a 850 cca battery that's is only rated at 38 amp hours.
Agm and deep cycle batteries are usually rated in amp hours. Car batteries including agm are rated in CCA. It's a very in important number to get right. You can not calculate amp hours from CCA.
I'm so far down this rabbit hole, you dont want to know.
Again. You want good info, go to candle power forums and decide for yourself.
Diesels need a good CCA battery, amp hours, not so much but definatly more important than in a typical gas car.
The reality is you never discharge a battery more than 15 to 20% max in a car that is working properly. You should never go below 60% in a typical car battery and never lower than 50% in a deep cycle agm. So it does not matter what battery you get honestly.
Nitpicking over what battery you get is like some of these guys who only run VW oil, and parts, because some of us are that anal about our cars.
Why spend more money on a part your going to replace anyways. Just dont let it stand you in the dead of winter in some back roads!
Old September 11th, 2019, 07:00   #9
scooperhsd
No - I will stand on my statement that you buy a TDI battery on AMP HRs - period - EVEN IN NORTHERN CANADA / NORTHERN ALASKA !
Old September 11th, 2019, 07:05   #10
Mongler98
Please ready my post above in response to this you cant go off amp hours alone. While your on the tight track, your misinformed on how batteries are rated.
Old September 11th, 2019, 07:05   #11
scooperhsd
You want AMP HRs in a TDI because
1- Glowplug power draw
2. Starter draw (especially when it has to turn more because of cold).
Old September 11th, 2019, 07:06   #12
JSWTDI09
JSWTDI09's Avatar
Originally Posted by LMJ View Post
....and how do I determine now that mine is a 6.
Probably, you can tell by the warranty. I suspect that both batteries (2 and 6 year) are nearly identical inside. My guess is that the biggest differences between them are the price and the warranty. Warranties can be expensive.
Have Fun!
Don
2009 Jetta SportWagen TDI (gone but not forgotten)
2018 VW Tiguan SE (I wish it was a TDI)
JSWTDI09 is offline   Reply With Quote
Old September 11th, 2019, 07:06   #13
scooperhsd
YOu certainly don't buy on CCA alone either. SInce they have nothing to do with each other..
Old September 11th, 2019, 07:07   #14
scooperhsd
And we have had these battery discussions over and over and over again in the 16 years I've been on this board.
Old September 11th, 2019, 07:10   #15
scooperhsd
You buy a battery with enough AMp Hours - (72 or 80) - it will have enough CCA.
The reverse is not true.
Need some advice: no start for 1 yr. ArkhamTDI Ontario 17 April 9th, 2016 20:57
Sirius Activation $77/yr Dave McDufford VW MKV-A5 Golf/Jettas 65 September 18th, 2012 18:43
New car has sat for over 1 yr. trouthog TDI Fuel Economy 21 April 6th, 2008 00:08
Looking for what yr ? John T F General VW Discussion 0 August 6th, 2006 10:27
Your opinion on 2 Yr. Warranty? csimo VW MKIV-A4 TDIs (VE and PD) 2 December 2nd, 2000 16:55
Page generated in 0.16289 seconds with 13 queries
[Output: 130.00 Kb. compressed to 108.95 Kb. by saving 21.05 Kb. (16.19%)]
