Old August 30th, 2019, 02:14   #1
9755
Default Alh turbo on mk1 1.6 n/a
I've been restoring an mk1 rabbit I picked up a few months ago. It's an n/a 1.6
I've also got an extra vnt15 laying around. Now im almost positive it will bolt up. But does anyone have any idea on how to make the wastegate function properly? I'm well aware of the engine not being able to handle much boost. Seeing if this adventure is anything possible
9755 is offline   Reply With Quote
Old August 30th, 2019, 04:04   #2
eddieleephd
Fuel Economy: 38mix / 47@70-75
It's a VNT vein not a waste gate. It's actuated by vacuum.
More vacuum, more boost.
'02 1.8t Jetta Wagon Alh w/5spd swap, SB 21#SM DD, bew lift pump, 11mm IP, VNT17, Malone stage4 tune, Stealth pipe, BMW Cyclonic CCV filter, 2.5"cat back st. pipe,Vr6 brakes, 2" lift, Panzer, Bilstein HD, fill tube ectomy, soon to be Wuzetem p.520 PD_fuel_delivery TDI Search Plug release tool Howto terminal release tools VW/Audi
eddieleephd is online now   Reply With Quote
Old August 30th, 2019, 04:09   #3
oilhammer's Avatar
Fuel Economy: fantastic
I would not attempt that.
Couple reasons:
First, if your 1.6L is the early one, the headgaskets are hard to keep bolted down already. If it is the later one, that is better, but still not ideal
If you get an even later 1.6L, the hydraulic one, you can at least upgrade to the MLS headgasket from an AAZ engine.
However, the factory 1.6L turbo engines had a far more turbo-friendly compression ratio (different pistons) as well as piston cooling jets and an oil cooler (your current engine has none of those items).
You would be better off finding a factory turbo 1.6L, but these were not super common even when new. They were only found in some Audi 4000s, Quantums, a handful of later A1 Rabbits and Jettas, and a handful of early A2 Jettas. I think the whole model year span was something like 1983 to 1986. The ECOdiesel Jetta, which came out mid-91 through 92, was also a turbo, but a very light pressure low emission unit with only a wee bit (7) more HP than the non-turbo version.
Once you realize how unobtainium those early TDs are, not to mention parts for them (as well as parts for the NA version for that matter) are quickly going away or are already gone, you may consider just converting it to a TDI engine. These are more readily available, the early TDIs (B4 Passat, A3 Jetta) are the same engine family as what you have, so they will bolt right in, and those engines easily outlast the rust-prone A3 bodies. You can also convert them to "M-TDI" meaning to run without any electronic controls if you wish. They are a simple wastegated turbo (the VNT is not) so can be easily controlled by what is already there.
www.cardocautomotive.com
Old August 30th, 2019, 04:57   #4
9755
I have been looking for a 1.6 turbo for a while and have found zero that were under a grand. I had considered doing a Tdi swap. But again I'm having a time finding anything reasonably priced that's under a few hrs away. Sounds like if I can't find something i like price wise, I will keep it n/a. As it will only be a weekend cruiser
Old September 1st, 2019, 12:14   #5
AndyBees
AndyBees's Avatar
There may be some info here .... http://vwdiesel.net/forum/
Also, seems there is another site for the IDI engines.
This is the TDI Club, a place to share experiences & ideas, ask for help, etc. Welcome Newbies! Sarcastic and condescending posts shouldn't be welcome.
AndyBees is offline   Reply With Quote
Old September 1st, 2019, 14:00   #6
bbob203
TDI(s): b5.5v
Fuel Economy: 38-42
Sell your 1.6tdad well as the vnt and use the money to buy an AHU, a k14 turbo from an AAZ motor and an MTDI pump. I had this setup in a b3 passat it was a great motor.
bbob203 is offline   Reply With Quote
Old September 1st, 2019, 21:56   #7
Steve Addy
TDI(s): 97 Mk3
1.6TD are hard to find, I've had one from a 1988 Canadian Jetta sitting on an engine stand for 18 years still haven't managed to get it done. It was supposed to go in my 86 Golf D, then it was going to be changed to longitudinal and wedged into my Fox 2dr sedan, which never happened because the 1.6NA in that car ran good and someone wanted to buy the Fox real bad.
Steve
the magic triangle spins in the peanut and then apex seals come out
Old September 5th, 2019, 09:05   #8
9755
I could sell the engine. But in my area people are struggling to sell them at $200. The cheapest I've found an ahu in my area is $1200. And almost a grand for an aaz
Old September 7th, 2019, 19:03   #9
[486]
TDI(s): 02 golf ALH
you can set up the actuator with a normal boost actuator can, then screw in the stop screw until your EMP at unloaded cruise is tolerable
you however should be aware that with the mechanical governor you have zero torque control, so you're really only doing it for altitude compensation and EGT control when loading it more harshly than it'd typically see. If you turn the fuel screw up too much you'll push the head gasket out real fast.
a much better suited mod for an NA IDI is to bump up the max speed governor so you still get full fuel past 1500 RPM, you would do well to wire up a rev limiter to the shutoff solenoid though.
Old September 8th, 2019, 05:52   #10
Taco8v
TDI(s): Alh wagon
I had done 2 of this 1.6 n/a to diesel with a vnt turbo and honestly i did put a choke cable ran it to inside the cabin. And I moved the vanes manually.
Yes i moved manually but I found out the turbo on small side it builds way passing 35psi. And thats just passing 1500 rpm so what i did was only to set the turbo at bigger side and taking off it lagging for a couple seconds but from there i have turbo all the time and it doesnít build boost as the vanes set to small side so I ended just removing the choke cable for the vanes and leave the vanes rod at open turbo vanes and after 5 years the i did it. the car still working fine
Taco8v is online now   Reply With Quote
Old September 9th, 2019, 09:06   #11
9755
I also contemplated leaving the vnt actuator and screwing it in or out until I find a moderate boost level. Id assume it would be full boost from the get go. Not exactly what I'm looking for. But I do have a lead on an ahu and trans. Hoping it pans out
Old September 11th, 2019, 05:42   #12
Taco8v
TDI(s): Alh wagon
That or just look online for a small external waste-gate and weld it into the egr exhoust coming from the turbo manifold i did that also and i can have more control of the turbo. (Check my build at instagram tacovw)
And man you should hear the sound of that external from my diesel black smoke from under the hood lol
Old September 11th, 2019, 16:57   #13
9755
I also had considered cutting the turbo from the manifold and welding a plate to mount a different turbo on. I'm in zero rush so I'm open to other options and opinions. And if I can piece things together over this winter thats fine with me. This will only be a nice day/weekend cruiser. The only reason I'm looking to add the turbo is because my ol lady drove it the other day around the block after doing breaks. And it being about as fast as our lawnmower has her concerned for when we actually do drive it.
Old September 16th, 2019, 08:42   #14
Taco8v
TDI(s): Alh wagon
Mmm manifold is cast iron i donít think it will hold man. But hey you can try
Old September 16th, 2019, 11:07   #15
9755
Cast isn't hard to weld to. Just need to heat it up and weld with nickel rod. But I haven't welded steel to it. I could also make a manifold and go from there. Still depends on if I can work out a deal with a guy that has an ahu
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
brady rogers
ALH haldex mk1 rabbit pickup Caddysmack TDI Conversions 12 August 18th, 2015 10:02
Alh mk1 project build jolfmantrev TDI Conversions 40 December 28th, 2014 17:55
ALH-mTDI into a Mk1 Caddy GTICorrieri TDI Conversions 10 February 28th, 2014 06:08
ALH or BEW into a mk1, anyone? CGDoig TDI Conversions 2 August 19th, 2011 17:29
any links or info on putting ALH into mk1? tdi_volks TDI Conversions 1 November 14th, 2007 21:13
Page generated in 0.16709 seconds with 13 queries
[Output: 125.11 Kb. compressed to 104.57 Kb. by saving 20.54 Kb. (16.42%)]
