Redneck Truck
Gone, but not forgotten
- Joined
- May 3, 2009
- Location
- Plano, TX
- TDI
- 2008 Touareg V10, 2001 Audi TTQ Roadster TDI 6-speed, 2005 Jetta Wagon TDI 6-speed
In case anybody else has done some digging and wouldn't mind saving me some time, I'm in the market to decrease boost temperatures, engine bay clutter, and plumbing.
So how about a small unit (fluid intercoolers that support 350+hp are not that big) plumbed directly into the cooling system so the water leaves the radiator and immediately enters the intercooler? you'd have to plumb a charge pipe from the turbo to the IC and the IC to the EGR valve, and you could stuff the intercooler wherever it would fit, like a book in a bookshelf, rather than directly in the airflow from the front end.
The I/O boost fittings on the unit I'm referring to are 2.5", and while I don't know the air volume of such a unit, but it would seem that eliminating lots of piping from a turbo to a front mount and back to the firewall again would more than outweigh the loss resulting from employing an intercooler that's a little too big for your application.
My questions are:
- has anyone else employed such a setup?
- does anyone know the temperature and (preferably convenient) location of the coolest water in the cooling system?
- how about using the hoses for the EGR cooler to cool the intercooler instead?
- how cool does the water entering a fluid intercooler really need to be, in order to be effective? obviously there's a reason they have a separate cooling system, but what if it could be done at least almost as effectively without a separate cooling system?
what do yall think? i'm staring at this 350hp unit on frozenboost.com and about to pull the trigger. anybody have any thoughts before i start dumping money and experimenting?
My questions are:
