Old May 19th, 2017, 04:30   #1
charlieruu
Fuel Economy: who cares
Default S177 Fuse Blown
So I'm kind of in a pinch. My fuse for my 90 amp alternator blew up yesterday and I don't know what to do. I need my car today in a few hours. Do any auto parts stores carry a fuse like that? Do I need a 90 amp fuse or a higher amp? I can't read what the old one says because its all burnt. How fast can I get my car driving again?
charlieruu is offline   Reply With Quote
Old May 19th, 2017, 07:04   #2
runonbeer
Maintenance EnthusiastVendor
Fuel Economy: amazing/excellent/still pretty good
You need to replace the whole fuse box and the alternator cable. Do a search on here. Common problem
runonbeer is offline   Reply With Quote
Old May 19th, 2017, 08:00   #3
eddieleephd
Fuel Economy: 45-51.9
in areal pinch I would consider using some copper wire that's rated at 90 amps via electrical code.
I actually have some heavy gauge copper, like the power lines going down the road, and I would pull out a strand and either single it or double it to meet the same volume of metal as the 90 amp fuse.
This is not the safest! It is far safer than bringing the wire across and leaving out a protective device at all!
I actually had an issue in an old Dodge truck I had and ended up twisting a single strand across the burnt out element. I never had any issues with it and tried another fuse as well; the truck wouldn't start without that circuit, otherwise, I would likely not have tried it in the first place.
That being said, fuses are generally rated at for maximum circuit potential (startup energy rating) and if the fuse has blown then there is likely another issue causing it.
Runonbeer is usually correct and I would follow his direction.
Any modification of the electrical circuit over current protection has risk, limiting that risk is important and never do it if you're in any way uncomfortable with the possibilities.
I always use a single strand wire that is comparable, maybe 5% more potential than the original conductor, when modifying a circuit for temporary or permanent use!
We must always remember that any and all modifications we do are done at our own risk!
Not that you don't know that already.
stealership is probably holding one right now though too.
2003 Jetta Wagon Alh w/5spd swap, 11mm IP, VNT17, Malone stage4 tune, BMW Cyclonic CCV filter, 2" lift
eddieleephd is offline   Reply With Quote
Old May 19th, 2017, 09:13   #4
BobnOH
Fuel Economy: 50/45/35
Fuses are devices designed to protect electric circuits. When a fuse blows it often indicates a component is drawing too much power because it's broke or shorted to ground.
I would not put a penny in the fuse, if it's a huge draw causing the fuse to blow, you could have a fire.
That being said, often those things on top of the battery sometimes corrode to ground, meaning you can just clean up the mess and drive on. Replacing the whole fuse box set-up is often the best solution as the corroding will trash the contacts.
BobnOH is online now   Reply With Quote
Old May 19th, 2017, 09:27   #5
CoolAirVw
CoolAirVw's Avatar
TDI(s): Jetta
Fuel Economy: 40
Post number two is probably right. Cable develops resistance where it meets fuse box. Resistance makes heat and the fuse box burns or melts or maybe if caught early might just have minor cosmetic damage. Fuse is damaged in the meantime.
If your so desperate order parts overnight, rent or borrow a car.
Richard. ASE Certified Master Auto-Technician with L1 Advanced Engine Diagnostic Rating. ATRA Certified in Rebuilding, Diagnosing & Installing Transmissions. ASE Certified for Passenger Car Light Diesel Engine.
Now offering Malone Tunes!..............http://www.kansascitytdi.com/
CoolAirVw is offline   Reply With Quote
Old May 19th, 2017, 09:30   #6
tadawson
Note also that fuses are thermal devices - the excess current heats the link, it melts, and the circuit disconnects. Bad connections to the fuse holder can also produce extreme heat (hence the melted fuse box) and that heat can conduct to the fuse and cause it to open well under it's rated current. Look carefully at the overall situation and evaluate based on what you see . . . if all else looks good, and the fuse is drastcally blown open, it's almost certain there was a fault. If there is evidence of a lot of heat, then it may just be a high resistance connection producing it. And lastly, if the fuse failure is pretty clean (small crack in the link, not much black,etc.) it's possible that the failure may also have a factor of vibration/metal fatigue . . .
tadawson is offline   Reply With Quote
Old May 19th, 2017, 09:45   #7
charlieruu
Solved, some guy in my local group saved me and had one laying around. Also, the fuse blown was due to loose connection and it was not drastically blown open. Looks like the connection had corrosion on it too.
Old May 19th, 2017, 19:45   #8
hollowhead
hollowhead's Avatar
Fuel Economy: 40ish
Glad you got it fixed. For future reference audio installers that install big amplifiers usually have the bigger high amp fuses.
hollowhead is offline   Reply With Quote
2001 B5.5 N75 +12V cable damaged fuse blown but where is fuse HELP! kennyash VW B5 Passat TDIs 0 March 7th, 2017 17:45
s177 fuse smoking hot! cfuzz987 VW MKIV-A4 TDIs (VE and PD) 1 May 20th, 2016 22:18
Melted fuse block on battery - S177 Drewmeister VW MKIV-A4 TDIs (VE and PD) 12 November 16th, 2014 21:25
No start, fuse 38 blown, lamp in place of fuse CCM clicking rapidly WINDSORB4TDI VW MKIV-A4 TDIs (VE and PD) 4 November 27th, 2011 21:22
S177 fuse, why would someone put a 40A in? unixb0y TDI 101 3 October 8th, 2009 08:03
Page generated in 0.14809 seconds with 12 queries
[Output: 86.35 Kb. compressed to 74.49 Kb. by saving 11.86 Kb. (13.73%)]
