View Poll Results: Which turbo to choose for 400HP in the 1.9TDI PD
Garrett GT2359V (from Mercedes E320CDI) 0 0%
Garrett GTB2260VK 2 9.09%
Garrett GTB2260VKLR (Ball Bearing Turbo) 3 13.64%
Garrett GTB2566VK 4 18.18%
Borg Wagner S356 5 22.73%
GTB3576KLNRV 3 13.64%
Other? (Which One?) 5 22.73%
Voters: 22. You may not vote on this poll
Old March 28th, 2017, 11:40   #61
eddie_1
eddie_1's Avatar
Originally Posted by diffas View Post
I think TeroP had high reving PD, dont't have the dynosheet to give atm. Atleast past 5500 it was revving fine. It's about how fast max. HP is dropping. If you have 350hp @ 4500rpm and 340 @ 5500rpm, thats not bad even the curve is going down. I wouldn't call 1.9pd widebanded as stock, not far from 2000rpm. :P
Hi, how did you improve VE on your 4B at high revs? MAF upgrade? It's cool how you got power at high revs.
2008 A6 BPP 267kmh, 2003 Jetta Wagon ALH 150mph, 188BHP - 365 lbft, 170WHP Smoke free German Map, VNT 17/22, 11mm IP, 02M DRW 6speed, OMI, Lower IC pipes,FMIC, PD Lift Pump, 3bar map, ARL Sachs Upgraded/DMF, PP764s, CCV Filter, EGR delete, PD150 Intake, PD150 SRP, 2.5" DP with Magnaflow Cat & 2.5" Catback, R32 DSG Snorkel, PD150 Airbox/MAF, Custom Accordian, Ventectomy, Rear Fog, Euroswitch, 5 brake light mod, McNally EGT/Boost Gague, Scanguage II, Hidden Hitch, LED tails, Koni Reds, Depo
eddie_1 is offline   Reply With Quote
Old March 28th, 2017, 11:56   #62
diffas
diffas's Avatar
umm ... 4B?
diffas is offline   Reply With Quote
Old March 28th, 2017, 12:02   #63
eddie_1
eddie_1's Avatar
umm ... 4B?
Sorry it was A6 terminology 4B generation prior ~2005. 2,5 TDI is on 4B generation A6. I know you upgraded turbo, wondered if you also were getting enough air in.
Old March 28th, 2017, 12:08   #64
TDIMeister
Phd of TDIClub Enthusiast
Moderator at Large
TDIMeister's Avatar
TDI(s): TDI
We are generally in agreement.
Originally Posted by TDIMeister View Post
I am not talking about 1000-2000rpm as absolute values, I'm taking about the useful powerband range from surge limited max boost pressure to peak power RPM, eg 3700-4700=1000, 3400-5400=2000.
Originally Posted by Yucca View Post
Approx >300bhp 3500-5500rpm
Old March 28th, 2017, 12:10   #65
ryanp
ryanp's Avatar
This graph has an increase of 30bhp from 4600rpm to 5300rpm
This one does drop, but only by around 30bhp from 4600rpm to 5400rpm.
02M 6 Speed Conversions + Euro Parts - 6 Speed Setups for A4 + A5 platform,PD150 Intakes, TIP kits, Turbo's, Injectors as well as anything else!! PM Me! - Click HERE
ryanp is offline   Reply With Quote
Old March 28th, 2017, 12:11   #66
diffas
diffas's Avatar
Yes but still where that 4B came? I've never had one and probably never will. :P
B5 for life. I did basic head cleaning/porting, upgraded valve springs, bigger turbo and deleted maf around 6 years ago. :P Non vnt turbo S200/K27.
Old March 28th, 2017, 12:25   #67
eddie_1
eddie_1's Avatar
Thanks for the info. In Germany the A6 generations are more typically referred to as 4A, 4B(2,5 TDI), 4F and 4G, although also referred to as C4 through C7.
You can see here:
A6WIKI
Old March 28th, 2017, 16:18   #68
BigTurboAlh
Fuel Economy: 525 mi to tank
That was my hot tune lol when the car was a daily I have a 20psi smoke free tune.
hx30/35 hybrid, ARP head studs, fass fuel pump, CAT filter, SB stage 3, pd150 intake, 3in turbo back, 5x011 injectors, H-beams, asv pistons, fmic, frank06 cam, 11mm pump.
https://www.youtube.com/watch?v=j7rKM3YzI-A
CPPDiesel.com
BigTurboAlh is offline   Reply With Quote
1749 turbo from id parts/ 350 plus shipping. Moesauction! Private TDI Items for Sale/Wanted 3 December 14th, 2015 15:51
400hp 1.9tdi 8v P.D. papi123 TDI Power Enhancements 96 August 7th, 2014 20:54
charger per 330d 3000cc diesel, per avere +400hp mao76 Non VW Group Diesels 13 June 12th, 2012 05:57
WTB: Turbo for 350+hp rosen TDI Private TDI Items for Sale/Wanted 2 December 25th, 2011 08:01
Turbo VNT Jetta 2000 350$us Smog Private TDI Items for Sale/Wanted 3 February 19th, 2004 09:09
Page generated in 0.18907 seconds with 13 queries
[Output: 101.41 Kb. compressed to 88.54 Kb. by saving 12.87 Kb. (12.69%)]
