Lift needle sensor circuit short to ground. After clearing code it will almost immediately have a pending code, then within a few minutes max, the CEL and glow plug light will appear. Did some research and have begun troubleshooting. Read that this is usually an electrical problem. So far I have tried cleaning the connector, stripped the outer sheathing from the connector to the injector and found no breaks or anything. I tested resistance at the connector to the injector several times with my Fluke multimeter and it is always ends up around 15-16 ohms. The coil is supposed to test out 80-120 ohms? If the coil is indeed bad in the injector, would it cause this code? These #3 injectors are pretty pricey, would hate to replace, and it ends up being something else. I have not pulled the injector and checked it mechanically, nor have I traced the wire to the ECU.
Disconnected the harness to #3, now it shows P1247 Needle Lift Sensor Circ. Open/Short to B+
