Old November 29th, 2008, 14:14   #1
gor131-x
Default First ever DYNO results,not right? DYNO PLOT pic
had the car dyno'ed today for the first time since doing the mods,and from a 115,i got 161hp with 150 whp,however,it didnt run very smooth and even though the new uprated sachs clutch with new DMF has only 300 miles on it,it was still shuddering really bad,is it the clutch/DMF setup or is it the map?
thanks
Passat Pd115,
PD130 Injectors,
FMIC,
Sachs Performance Clutch and DMF,
PD130 boost solenoid valve,
Upsolute Stage 1 Remap
161bhp
Going for the 200 mark!!!
gor131-x is offline   Reply With Quote
Old November 29th, 2008, 14:49   #2
mojogoes
TDI(s): mk3 tdi golf
Fuel Economy: not much
A3 / mk3 golf with 249Whp "Now in the hands of someone else"
mojogoes is offline   Reply With Quote
Old November 29th, 2008, 14:53   #3
johnnloki
johnnloki's Avatar
TDI(s): 04 Golf TDI
Fuel Economy: 1100 km tanks, generally
You're supposed to be nice and gentle to your clutch for the first thousand or so miles. Dynos aren't gentle.
johnnloki is offline   Reply With Quote
Old November 29th, 2008, 14:56   #4
Good Ol' Boy
VeeDubTDI's Avatar
I disagree... you usually engage the clutch gently on the dyno. When was the last time you saw a dyno operator banging gears on the rollers?
Old November 29th, 2008, 15:01   #5
johnnloki
johnnloki's Avatar
TDI(s): 04 Golf TDI
If a clutch is starting to go, a dyno will expedite it. Remeber the Montreal Dyno day? Lots of badly slipping clutches. Dynos are hard on clutches, not because of engagement, but because they put a load on the car and give more resistance than the car should see normally.
All that said, though, it's possible that the dyno plot just hasn't been smoothed- most plots aren't pretty curves, but are jagged jumps that are smoothed out by the software of the machine.
Old November 29th, 2008, 15:02   #6
Bob_Fout
Oil Wanker
Bob_Fout's Avatar
New clutches don't have the rated holding power until broken-in, nor is the mating surface smooth.
300 miles might have been too early, 500 miles is what most clutches are. Some are as long as 750 miles.
2003 Jetta TDI (sold) / 2015 GTI 2.0T
Photos | Mods | CJ-4 Oils | Oil Analysis | Stage II Cam
Bob_Fout is offline   Reply With Quote
Old November 29th, 2008, 15:37   #7
gor131-x
i got the clutch supplied & fitted from awesome gti and they said 250 miles and ive done around 350 when the dyno was done
ill be taking the car to the remapper on tuesday,im going to get the car put to stock and see if the clutch and or the car shudders,if it does then its the lcutch but if not then its the remap,but awesome were pretty confident the cause of the jumps was the remap done badly,mainly because i had pd130 injectors put in and that i could do with a custom remap
but normal 115's normally do 145 bhp,dont know if thats whp or at the flywheel but the guys there were impressed that i got this from a 115 from just bigger injectors,FMIC and a remap
Passat Pd115,
PD130 Injectors,
FMIC,
161bhp
Old November 29th, 2008, 16:03   #8
fenwick458
fenwick458's Avatar
i got 159bhp out of mine with just a map, then with a decat, smoothed box, cleaned manifold, egr delete it got 167bhp.
those are all flywheel figures, everything in the uk is flywheel.
i used to get loadsa flywheel judder on mine, then got a good map, fettled the clutch off, got a paddle clutch and new DMF and not felt it judder since
fenwick458 is offline   Reply With Quote
Old November 29th, 2008, 16:14   #9
gor131-x
mine was 161 bhp at the fly,according to what you just said,i should have got better than that as ive got the FMIC,and the bigger injectors,
just shows that the remap isnt a good one then doesnt it
ill carry on driving gently until the clutch has been bedded a couple of hundred more miles,but DAMN! just hearing that you got those figures from just a map makes me feel like ive just wasted my money on some of the mods
i remapped my old car which was 90bhp AHU engine code,and it overboosted and finished the turbo,thsi was done by chippeduk who if it wasnt for a VAG technician that wa spresent at the time there,i would never have known,but they still didnt own up to it,they used a map from a 110bhp because they couldnt find the right map for my engine,pretty much sums them up,sorry if im being harsh about chippeduk but i did not like jasons attitude whatsoever,
and upsolute is a recommended remapper on loads of forums which is why i went with him
2 different remaps,both not working out for me,
Passat Pd115,
PD130 Injectors,
FMIC,
161bhp
Old November 29th, 2008, 16:57   #10
mojogoes
What do you mean ChippedUK there great............................................. .............................NOT!! i've heard alot worse i'm afraid.
Old November 29th, 2008, 17:13   #11
KROUT
persona non grata
That all depends on the material the clutch is made from. I used to use luke clutches in my many 4x4 toyota mud trucks. I took it right from the garage to the mud. Never had one fail or slip. Never gave any break in time. Redlined the crap out of it with less than 50 miles on them.
Now these new feramic clutchs I agree have to be broken it.
KROUT is offline   Reply With Quote
Old November 30th, 2008, 11:10   #12
gor131-x
i just didnt want to start an argument on here about chippeduk,but im glad im not the only victim
well this is the sachs uprated clutch and is rated to 420NM torque,it drives fine now but i havent done a racing start yet and im not going to yet either,just a couple hundred more miles
Passat Pd115,
PD130 Injectors,
FMIC,
161bhp
Old November 30th, 2008, 20:38   #13
hatemi
If youre getting 160+ with the stock VNT15 then your tuner must be an total amatour with no knowledge of whats the safe limit of the parts. EMPs must be just crazy....
www.tdituning.fi
hatemi is offline   Reply With Quote
Old November 30th, 2008, 20:56   #14
Gothmolly
TDI(s): 2002 Golf
Or the dyno is crap.
!Vent, !DRL, 5 brake light mod, 11mm pump, RC3, Bosio Sprint 520s, VR6/G60 clutch, missing belly pan, leaky CCV, leaky valve cover, leaking door seals, broken glovebox, broken horn, rusted fender, dead rear windowwasher, frozen axle bushings
Dead radio? Pull fuse 42, wait 60 seconds.
Gothmolly is offline   Reply With Quote
Old November 30th, 2008, 21:44   #15
Farfromovin
Torque Addict
Farfromovin's Avatar
Fuel Economy: low: 35 high: 56 avg: 42.0
PD115's have vnt15's? Learn something new everyday. Yeah, you need a much bigger turbo to continue your hp quest for sure...
[/old setup]212whp/354 ft-lbs14.862@96.677-Way faster than Chris [/new setup] At least 213whp, and way way faster than Chris.
Farfromovin is offline   Reply With Quote
Page generated in 0.18073 seconds with 10 queries
[Output: 124.22 Kb. compressed to 102.93 Kb. by saving 21.29 Kb. (17.14%)]
