Does 3.16 R&P takes same LSD?
MAXRPM
US
00 Jetta and 99.5 Golf, 2015 Passat TDI,BMW 2
I have a 3.16 R&P from a passat, that I need to install in my ALH manual 02J, now if I were to buy a LSD for the manual O2J will it still fit in there or do I have to get a different LSD from other model?
[486]
MN
02 golf ALH
no carrier break, they're straight helical gears not hypoids, so the flange is in the same position on all of them
MAXRPM
US
thxs so no can do
algirdas
Cincinnati,OH (Dubwerx)
98 jetta AHU
3.16 fits in ALH trans. I’ve installed several.
Buy the LSD for the ALH and 3.16 R&P fits.
Really good mod for a strong engine, 1st gear gets usable, not too short.
MAXRPM
US
from Bora parts (German cascade)
[486]
MN
02 golf ALH
There are aftermarket honda ring and pinion sets available, wonder if someone in china'd tool up and make some for the 02j? Could probably make some 3.00 or higher.
Ran the numbers long ago and a 2.70ish final drive would make the ratios on a dirt common 2.0 gas trans really good with the TDI. No idea if the pinion would fit in the space they give in the trans case though.
loudspl
Osakis, Minnesota
02 ASV w/ 02J
2.70-ish would be sweet.
.700 or even stock .756 5th would do well with that.
1st gear might pull stumps, but it's useless in normal driving :p
Figured I would try to nab one of these before they disappear completely.
I'd bite for a Chinese version if someone on Ebay pops up with one.
[486]
MN
02 golf ALH
nah, 1st is the same in 2.0 gas and tdi, so it would make 1st actually useful instead of like on the TDI trans where you can easily ignore first.
loudspl
Osakis, Minnesota
02 ASV w/ 02J
Yes, longer gears overall.
1st will finally be useful and won't need to upshift so quickly when accelerating.
Had plans for an 02M but this is a good compromise
mrchill
TDIClub Enthusiast, Super Secret Diesel Ninja Vend
MASS! home of THE WORLD SERIES CHAMPION RED SOX! x
96 B4v red \ 98 Mk3 green\98 Mk3 Jetta black\ 99 Mk4 Jetta green x2\ 99 Mk4 Golf silver x2\ 99 Mk4 Jetta black\ 97 B4 sedan green\04 JSW gold\03 JSW silver
Ive built a few of those...if you add a taller 5th(not too tall) its a great option for those not wanting the 02M. You will have a similar ratio spread to the six speed overall
MAXRPM
US
which of the tallest 5th .681 .658 or .622?
loudspl
Osakis, Minnesota
02 ASV w/ 02J
.681 is no longer made, .622 really tall and probably only good if you run a small turbo or looking for records on the salt flats.
.658 is good but maybe too tall combined with 3.16 R & P.
A .700 5th might be a better daily driver.
Really depends on what speeds you are at the majority of the time
MAXRPM
US
so .658 5th gear that i believe is a .734 going at 80mph gives you 24k rpm with 15inch wheels,
I'm going to install 316 R&P with .658 and 1756vrk hopefully I can do 80 mph and drop rpm 22k or 23k rpm. I will report back and be installing 17inch wheels
Chrislupo
Germany
Lupo3L1.2TDI,Lupo1.4TDI,Golf51.9TDI
ASD, DTA, EXB all have the 3.157 diff and 3.3 1st gear. Quite common in Europe.
I have the EXB with .658 5th gear in my lupo.
In my opinion you also need a longer 4th.
I use Audi A2 GRJ .9032 4th instead of EXB .09714.
MAXRPM
US
I'm always paying attention
MAXRPM
US
ok so now the question is, , does the 3.16 R&P from a passat need a Peloquin LSD 02J or O2JB to mate up? Anybody knows? they sell both so which one?
[486]
MN
02 golf ALH
their site says 02jB is for 04 and up and mentions the ring gear diameter being different
since you're using gears from an even older trans...
