Hallo Guys,
My Name Is Marco, I am 24 Years old an i live in Germany, Bavaria.
I am currently building a Golf MK1 with Golf 3 1.9TDI AFN engine. The problem is, diesel engines are rarely tuned in Germany. That's why I hope you can help me further.
My Goal Is to reach 250Hp with the AFN Engine.
So i got a lot of Questions ��
1. How much NM can the Original Rods?
I wanted FCP H-Beam Rods including ARP 2000 Rod Bolts, Mahle Pistons, ARP Crank Mains and ARP Cylinder Head Screws.
2. The Original Pistons are already MAHLE. Should I use the old ones or buy a nee Set?
3. Original Inlet Manifold from the 1.9 PD Engine or a Custom Aluminium from Darkside Dev.?
4. Exhaust Is already 3“ without Cat, only 1 Muffler at the End. So I think this Is ok ��
5. Which injection nozzles and which piston diameter of the distributor pump?
6. Which clutch package? G60 single flywheel? Sachs Performance 4Pad? It is a 5-speed 02A transmission (ASD with the long 5th gear)
7. Which MAP sensor? The original can only go up to 2 bar
8. Performance Camshaft with how much Degrees?
9. Last and most important question. Which turbocharger? OEM, Stage X or Hybrid? What can you recommend to me?
What is very important to me, he must have an early response.
Nice greetings from Germany
