GTSLOW
So I recently swapped my radio from my 2015 SE Passat to my 2012 Jetta. Everything works great. Now I want to swap the backup camera over as well. Looking at the trunk handle on both they look identical, except one has a camera and the other doesn't.
Now looking at this kit:
It seems there should be a separate wire or harness running to the back of the car on the Passat. Does anyone know if this is correct? What I don't want to do is pull the carpet up and everything only to find it combines into the main harness or something.
If anyone has experience with the backup camera system on a B7 and can give some advice I would greatly appreciate it!
