First,
That one will definitely NOT fit anything other than a B6 Passat.
Second,
I would never ever buy a used clockspring. The one pictured is not locked in the dead center position and as a result it could be installed 360* out of rotation. I know, it sounds odd. But let me explain.
I don't know for sure the amount of rotation the clock spring has, but I believe it is 900* (2 1/2 turns) of rotation each way from dead center. Well, if you installed a clockspring that was "centered" at 360 of right rotation, you would only have 540* of right rotation, but 1260* of left rotation. And if you did a full lock turn (900*) to the right, you would tear the wires inside.
Geez I hope I did my maths right...
