Ramairetransam
Well ive noticed no ones brakes warp or need to be changed or they pay so through lots of research i found out what i needed and did it .
I did all the rotors and pads in about 2 hrs . I got drilled, slotted and zinc washed rotors with pads for about 210 shipped.
Brake o motive was the seller i used and my brother has used them for his firehawk and for his gfs mazda 3 . They work great and dont rust, and ship quick.
The reason mine were warped is bc the car sat so long before i bought it . Only the rear were messed up but since i had all of them i did them all .
Btw my fronts were replaced when i bought it with 28k on the car and no has 51 and the front pads and rotors are perfect , dont know if anyone wants to buy them .
Special tools needed for me , a gm guy were a triple square set , and a caliper wind back tool .
You only need a 14mm triple square unless you wanted the whole set like i did.
First time doing a brake job on a vw and a nms passat and everything went as smooth as possible .
But if anyone has any questions i can help anyone out .
