MakingBoost
I'm doing some work and need the torque specs for the bolt that holds the front wheel bearing together to the driveshaft. In all the cars I've worked on this is a nut. Not sure why VW uses a bolt?
Thanks but I don't think that is correct. I found a service manual which specs the bolt to 200 N-m (148 ft-lbs) and then 180 deg.Depends on what bolt style you have. Sin e you have an mkvi I will assume you have the new style. That bolt is supposed to be replace after removal. The torque is 70nm plus 90*
Over 17k miles on the car and no problems with the wheel bearings.I hope your wheel bearing lasts.
Downpipe and tune is awesome. You can feel more exhaust vibration through the car which I don't care for, but that is far offset by the MPG improvement, TQ, improved drive-ability and increase 'fun-factor'!PS how do you like your downpipe? and how hard was the install?
