Hi,
I own a Volvo V70 2.5 TDI (5 Cylinder Engine, not the V6 TDI from Audi). it uses a VP37 11mm Pump and has Stock 0,216 Nozzles.
The Engine Code is AEL.
I changed the ECU to a EDC15VM+. A Few months ago I bought some cheap 0,320 nozzles (Well to be true I think its not the exact size). They work, but I had often issues with starting the car even with glow plugs. So I swtiched back to the Stock nozzles this weekend.
I have experiance with the 1.9 PD TDI, so I am not new in this Topic (btw. I am sorry for my english, which sometimes might be hard to understand )
My Goal with this car would be around 260HP and about 550-600Nm of Torque. These values should be easy reachable with this engine. but I still would be Happy, if some of you could help me to pick the right parts to get to the power I am aiming for.
What noozles would you recommand and which Turbo?
I need about 80mg/H of fuel, soe the nozzles should be maybe 80% bigger than the Stock ones are?
From my calculations I should need about 2,1bar of boost until 4500rpm....but it would be better to have some extra room to get higher
Of caurse I would like to have some plug and play stuff, because its just easier. At the moment the Stock K14 Turbocharger is doing the job, with about 1,3Bar.
How much Fuel can my Stock injectors deliver? The Map only goes to 50mg/H but it shouldnt be a problem, because I just have to raise the voltage and adjust the map a bit.....which leads to the next question:
Is there a way to calculate the Duration of the Injection via Voltage?
The calibration of new nozzles isnt a Problem, because I have a Wideband o2 sensor attached.
Well, I think thats enough for the start
