puchfinnland
Hello,
Mike from Finland,
I just bought my new project-a vw fox wagon(in USA)
http://forums.vwvortex.com/showthread.php?5949900-FS-Clean-and-sorted-88-VW-Fox-GL-wagon
I am moving statesid this summer....
I seriously want to swap a 1.4tdi in, it will not be a walk in the park...
I note-
custom oilpan fabrication,must clear the crossmember due to starter moving to the right side,
custom mounts for left side of motor,
maybe the right also.
then to get the thing running...
QUESTONS!!!!
I am hunting for a motor, or even a complete donor car- I have found in finland
what unit should I be looking for? I have heard some have better turbos with round exhaust flanges.
what all will I need to take from the donor car?
im figuring the instrument cluster,
the coded ign lock setup?
the complete harness and computer
the alternator
as much of the AC as I can get
intercooler
radiator -why not
the fuelpump in the tank
the cat, and parts of the exhaust
dont need powersteering, do want to keep the A/C as its hot in Baltimore Maryland.
Im not so concerned about HP- but if I can find a 90hp, and get a comfortable 100 out of it and better mpg-its worth the investment.
I am a trained mechanic, so I am fully aware of what i will be up against.
a wrecked 1.4 polo,engine is toast, but the ECU,harness ,exhaust downpipe, AC compressor, may be avail.
a used motor guy has a 90hp version sitting in the warehouse an hour drive from here...
Or I just drive into DE, and go to a wrecking yard and remove as much as i need.
I got 3 months to obtain my lump- I am willing to buy from a forum member
also how difficult will it be to get this in to USA?
PLEASE HELP with advise!
mike
Mike from Finland,
I note-
QUESTONS!!!!
the alternator
intercooler
radiator -why not
mike
