Hi C4 owners !!
I have an Audi A6 C4 R5 2.5 TDi AAT engined.
So far, only mod was a chip-tune I made on my own. Turbo is K14 stock.
I can tell from this experience that the car is very good, probably around 150hp with barely no smoke. Smooth spool-up and very progressive up to 4500rpm. I can push the tuning a lot harder... because there´s still a great margin for improvement here.
By looking at the fuel and turbo maps, it is clear that "hardware-only" mods to fuel are not the best option, because there are limitations in the stock program that will limit the new hardware potential. Specially in fuel delivery.
A lot more can be made with chip-tuning.
MSA-11 tuning is very old-school, but still, great improvements can be made.
I have an issue though : My car always blows a slight haze of smoke at idle. Probably unburnt fuel (
IP timing is correct by vag-com). When I stay long-time at idle and then I take off, the smoke becomes more apparent, sometime very visible.
Probably worn nozzles ? I still have the stock 0.205 nozzles. 234.000km.
If I do a long trip I see no smoke at all. But idling for a long time... iech....
Oil consumption is about 1 liter@5000/6000km
No coolant changes.
Made a compression test : All cylinder between 29/30 bar.
Any ideas ?
