Old September 12th, 2002, 02:07   #1
Anders
Default Is a GT1749V a VNT15 turbo ?
I have a euro tdi with 110 and on my turbo it saids GT1749V. I thought that the turbo on my car was the VNT15 ??
Please help....
Anders is offline   Reply With Quote
Old September 12th, 2002, 04:11   #2
HDIesel
Default Re: Is a GT1749V a VNT15 turbo ?
different name but the same turbo!!!
Are you still getting smoke with that huge IC?
HDIesel is offline   Reply With Quote
Old September 12th, 2002, 05:08   #3
SkyPup
Guest
That is the larger VNT15 with 49mm compressor wheel instead of the 46mm one.
ere are the Model Designation and Wheel Diameters for the older T-series and the new GTVNT Series Garrett Turbochargers:
(mm) (mm)
Model Compress Wheel Dia Turbine Wheel Dia
T2 48.0 47.0
T25 51.4 53.0
HFT25 54.4 53.0
T3 60.0 59.0
GTVNT15-46 45.7 41.2
GTVNT15-49 49.0 44.2
GTVNT25-52 52.2 47.0
GTVNT 25-56 55.8 50.3
The GTVNT15-46 replaces the T2 Garrett Turbo, the GTVNT15-49 replaces the T25 series, the GTVNT25-52 replaces the HFT25 model, and the GTVNT25-56 replaces the T3 model.
The inlet diameter of the newly designed impellers of the GTVNT series is slightly larger (0.56mm) than that of the corresponding T-series it replaces. When compared at a pressure ratio of 1.8:1, the flowrate efficiency at 65% on the surge side for the GTVNT is similar to that of the previous T3 turbo, while producing a much higher flowrate at 65% efficiency on the choke side! A significant improvement of 19% in useable flow rate is achieved. With a pressure ratio of 1.8:1 and a flowrate of 9kg/min, an increase of 7.5% in efficiency is noted.
During the initial phase of the development of the new GTVNT15/25 series Garrett turbochargers, a number of objectives for improving the current production turbines were sought. These objectives were: to improve the turbine flow characteristics, minimize size and weight, minimize inertia, improve transient response times, and to improve the aerodynamics of the turbine housing.
The new GTVNT turbine housing features improvements made through the modification of the waste gate housing as well as that of the tongue location. The wastegate flow section was improved by providing a straighter gas path for the bypass flow to exit. The tongue was positioned closer to the wheel inlet to minimize wall frictional losses in the region of high trangential flow and high gas velocities beyond Mach 1.
The new turbine wheel of the GTVNT25-52 series features a smaller blade count as compared with the earlier T2 model (9 vs 11) and also features longer blades and a higher trim than the T2 model (67 vs 57), although the turbine tip diameter is the same as that of the T2 (47mm). Turbine corrected flow plotted against turbine housing size for a constant turbine pressure (P1T/P2 = 1.8) for the new GTVNT25-52 shows turbine flows within approximately 4% of the larger T2 turbine and 30% higher than the equilivant sized T2 turbine. The new compressor wheel design shows the compressor wheel diameter vs airflow for the entire GTVNT family as compared to the T2-T3 series, has successfully achieved wheel size reduction for equal air flow rate.
Comparison of Features of older T25 and new GTVNT15-49 Turbochargers of Equal Compressor Flow Capacity:
COMPRESSOR WHEEL T25 GTVNT15-49 %Reduction
Diameter (mm) 51.4 49.0 4.7
Weight (g) 33.1 26.3 20.5
Inertia (kg-m2) .0000057 .0000043 24.6
TURBINE WHEEL
Diameter(mm) 53.0 44.2 16.6
Weight(g) 148.4 112.5 24.2
Inertia (kg-m2) .0000148 .0000103 30.4
TOTAL TURBO WT(kg) 5.43 4.55 16.2
SHAFT DIAMETER(mm) 9.2 7.9 14.1
TOTAL TURBO
ROTATING INERTIA(kg-m2) .0000208 .0000149 28.4
Corrected TURBINE FLOW (kg/min) at 1.7 Pressure Ratio and .47 Housing Size for:
Garrett GTVNT15-46 = 3.85 kg/min
Garrett GTVNT15-49 = 4.30 kg/min
Corrected COMPRESSOR FLOW 9kg/min) at 1.8 Pressure Ratio and 65% efficiency in 55 Trim for:
Garrett GTVNT15-46 = 7.8 kg/min
Garrett GTVNT15-49 = 9.8 kg/min
This data show that the new GTVNT15-46 turbocharger flow the same as the older and larger T2 series turbo, while the new GTVNT15-49 turbo flows slightly less than the older design T25 turbo. The reduction in size of the turbine housing, turbine wheels, and compressor wheels in the new GTVNT series turbochargers while maintaining comparable flow characteristics and improving the Performance Maps efficiency on the choke side of the Map has resulted in significant improvement in useable flow range over the previous T2-T3-T25 series turbos.
As the data from Garrett Motorsports Turbocharger Division of Allied Signal shows, there are two models of GTVNT15 turbos, one (GTNVT15-46) has a 41.2mm turbine blade and a 45.7 compressor wheel, while the other (GTVNT15-49) has a 44.2mm turbine blade and a 49.0mm compressor wheel. the larger turbine wheel and compressor wheel of the GTVNT15-49 compared to the GTVNT15 gives an 11% increase in turbine gas flow as well as a 13% increase in compressor flow.
[ September 12, 2002, 05:11: Message edited by: SkyPup ]
Old September 12th, 2002, 13:48   #4
PTC
TDI(s): HMaracic
Please help....
<font size="2" face="Verdana, Helvetica, sans-serif">Could you please check and tell us is your engine AFN, AHF, or ASV?
Thanks!
PTC is offline   Reply With Quote
Old September 12th, 2002, 22:07   #5
mickey
Guest
Yes, the 49V is a "VNT-15" with a larger compressor wheel than the 46V.
A VNT-17 is the next larger "family" of turbos.
I have a VNT-25 I bought on Ebay. It happens to be the smallest of the VNT-25 family. There are five or six larger ones, I believe. As I understand it, the "family" uses the same basic housings and center section. Just slightly different wheel sizes and trims.
-mickey
Old September 13th, 2002, 00:19   #6
nApkIn
so whats the vnt-17 for a type of name? gt1752V???
nApkIn is offline   Reply With Quote
Old September 13th, 2002, 04:46   #7
SkyPup
Guest
Here is a *****in' mo-fo VNT17 on a TDI-R PD race engine. [img]images/icons/grin.gif[/img]
Me Want.
[ September 13, 2002, 04:47: Message edited by: SkyPup ]
Old September 14th, 2002, 03:48   #8
Anders
No smoke right now. I have blown the turbo and I don't know which one I want. I will proberly get a VNT17 and see how that will work on my car.
I will also have the chip changed sp that I dont have 434 nm at 2000 rpm's. The driveability is not good right now. I want max nm at around 2500 rpm's.
Old September 17th, 2002, 00:49   #9
CADDY
nice turbo!!
i have an afn, what is the vnt on?
i think i have yhe small vnt-15.......snif. [img]images/icons/frown.gif[/img]
CADDY is offline   Reply With Quote
Old September 17th, 2002, 00:57   #10
Anders
Is your engine the 110 hp or the 90 hp ? If you have the 110 hp as I have you have the VNT15 with 49V. I will within two weeks have a new and bigger turbo (VNT17) on my car and when I will tell you all how it is running. I my also having my cam changed so that is also something that I look forward to test. More to come...
Old September 18th, 2002, 01:13   #11
CADDY
i have the tdi 110 first generation with old ecu (68 pin/ 1 connector).
made in 98
Old September 18th, 2002, 03:39   #12
nApkIn
where can we get those "vnt-17" turbos?
anders! i got an vnt-15 with a larger wheel like the number on the turbo says. but it is from a 130hp pumpe duse engine.. so what is the steady boost of the 130 hp engine?
and where the hell is a vnt-17 put in?????
cuall
Old September 18th, 2002, 19:12   #13
RedRotors
RedRotors's Avatar
-mickey
<font size="2" face="Verdana, Helvetica, sans-serif">Can you drop me a line? I'm curious if it's the same that i want to bid on it...
Marc
RedRotors is offline   Reply With Quote
Old September 19th, 2002, 00:09   #14
CADDY
ANOTHER QUESTION...
nice intake manifold ,were does it come from?
is it a special one for race?
Old May 27th, 2003, 23:14   #15
AtomicSushi
Fuel Economy: 47/37/32
Bringing up this old thread.....
I was wondering if the GT1749V with manifold as meant for the PD115 TDI is a bolt on to an ALH TDI?
Same housing, just bigger wheels.
Should said turbo be bolted on (and a larger intercooler attached) would this provide any improvement over the stock GT1746 when fueling is via PP520s and an 11MM pump.
AtomicSushi is offline   Reply With Quote
Page generated in 0.17922 seconds with 12 queries
[Output: 115.49 Kb. compressed to 95.78 Kb. by saving 19.71 Kb. (17.07%)]
