03TDICommuter
Is end play normal on an ALH IP? I bought a used IP as a spare and there was very little padding (box was as big as the pump). There is I estimate 1-2mm of end play on the camshaft sprocket.
Is this normal? I'm just hoping the pump wasn't damaged in transit.
Also, can the connector housing be replaced easily? It was pretty beat up in transit (outer shell smashed)
