Kevin G
My 2002 Jetta sprung a leak from the fuel return line (fuel was squirting out while the engine was running). This was the small return line from the injector to the pump, not the larger line to the filter. I turned off the engine, popped the line off, and popped on a new piece of hose. Now the car won't run.
It starts, gets to idle speed, then shuts down. If I put my foot to the floor while it is starting, the RPMs will go over 2K, but it still shuts down just as quick.
I'm new to the diesel thing, so I'm not entirely sure how everything works and how sensitive things are. But my logic is that it was running when the line broke and the engine didn't shut off, so I would't expect to have an issue starting it. Is the issue that I really do need to bleed the whole system?
Elapsed time from leak to repair was about two hours. Thank you.
