lmoretti
2006 Jetta TDI 5sp Manual Pkg 1 (sliding sunroof, TPMS, Heated front seats, Heated power mirrors, etc)
One owner, no major accidents (see below Issues section).
<116,000 miles.
MFG Date: 08.06
Asking $2500.
Things that have been done:
Oil Changes with Full-synthetic oil, Fuel filter changes, Air filter changes.
Timing Belt & Water pump (~90k miles, done poorly by Hall VW, fixed, then Timing checked by Jason TDR)
Sachs Quiet Clutch (~100k miles, done by Jason TDR)
New Continental Tires (~100k miles, Done by Discount Tire)
Radio head unit replaced with Kenwood Excelon DPX592BT unit w/ bluetooth & USB (old head unit in trunk, drains the battery overnight)
Issues:
Rear Coil Springs likely needs replacement.
Aux electric cabin heater likely not functional. (code visible with RossTech VCDS)
Intermittent driver window switches. (only driver window and front passenger: Likely either harness or door module)
Misc scratches and body damage, paint issues.
Cracked passenger mirror mount (parking lot while parked)
Cracked and dented rear passenger taillight (still functional, Backed into a railing at low speed)
Headliner falling.
Worn steering wheel
E-Brake needs adjustment.
Extras:
- RossTech HexCAN adapter
- PD Tuning Box (never installed, needs new ground wire)
- New in Box In-tank fuel pump
- Fuel filter
Pictures
<116,000 miles.
MFG Date: 08.06
Asking $2500.
Issues:
Headliner falling.
Worn steering wheel
Extras:
- Fuel filter
Pictures
