Lock_t
Not sure what's going on with my NSP egt gauge. I bought it used but the gauge works, i hooked it up to a 9v battery and it lit up before I installed it now that it's in it doesn't light up but when I turn the key on it does a sweep like it should. I've relocated the ground used brand new wire with only connections to the wiring coming out of the gauge. Probe was brand new I forget the brand but probe is located in egr block off plate but when I drive there is no egt reading from the gauge. Gauge is 600-2200. Any insight to why I'm not getting a reading would be helpful. TIA!
