GQ tuned chips in JB
jimbote
Certified Volkswagen Nut
Tacoma 4x4 converted to TDI
http://forums.tdiclub.com/showthread.php?t=148065
found this zombie thread ... pretty sure this is the issue as i've physically deleted the fifth injector solenoid.... gonna ohm the unit and replace with a resistor... my question is why vcds does not ID the code ? my software is only one update behind ... is this a software issue or a chipset issue ? and what do the "advanced id" alerts mean?
jhax
Golden, CO
96 Passat B4V, ALH engine out of a 2002 Jetta, some IE Rods and ASV Pistons. Nothing drivable yet though
Speaking of resistors, would you happen to know what resistors to use to replace the before and after cat temp sensors?
