justintime_3
BRM Cam Failure again?update Broken exhaust valve now
So a little about my situation. 06 Jetta TDI BRM 237000 miles
Bought the car in 2012 with 162000 on it and was told that the EGR had been replaced and that the cam and lifters looked ok but to keep an eye on it and that the TB was just changed and had receipts to show it. Got the car home and notices the burping sound coming from the intake. tell tale sign of a bad cam. So I opened up the engine cover and sure enough needed a new cam. No big deal I enjoy working on things. Called around and nobody had a Colt Cam available so I went against my better judgment and purchased an Oem one from KERMA TDI with all new lifters and everything that is supposed to be replaced. Installed it and ran great.
Fast forward to today and going home yesterday from work and the car just all of the sudden felt like it dropped a cylinder. It could barely keep speed and you could def tell it was having a hard time running. I limp it home another mile and park in the driveway pop the hood and listen to see what is going on. I have had the hissing EGR for about 5000 miles but have just been pushing it to the side for a while now and hoping that is not the issue. Anyways pull the engine cover and number 1 lobe is pretty worn down. Cant see if there is a hole in the cap but the chamfered edge is def gone on the lobe. Plug VCDS in and it states P0303 Cylinder 1 Misfire. The car now has 236000 on it. I have been running Rotella t6 the whole time.
So my question is it possible to burn through an OEM cam in 70,000 miles and if so is it possible to make the vehicle run so badly that it really has a hard time moving under its own power? Or should I be looking into a possible injector failure although uncommon on these engines?
Also a notable mention is I had a water pump lock up on me and partially shred the timing belt approx. 10000 miles ago. It never jumped timing but is at least worth mentioning.
