To PDeezul:
Hi, sorry for the delay in answering. MoGolfs proceedure looks correct to me...but getting to that stage (fitting the belt/timing the engine) is different on the Passat than the Jetta/Golf. The Golf/Jetta have transverse mounted engines (making it that bit more awkward IMHO). The passat engine sits fore and aft (as seen from the above pictures).
The tool i used for locking the crankshaft sprocket is as shown in the link..
http://www.toolsinstock.com/index.php?act=viewProd&productId=13902
Make sure you get the correct one for the P.D engine...first one i got had a different pitch on the teeth (although it could have still worked). I used a Haynes manual to do the job ( a bently cd/manual would be just fine for this job too).
Make sure you get the correct tensioner roller for your car before pulling everything apart....Upto year 2002 use a hydraulic type tensioner and from there onwards use the friction type tensioner as shown in the above picture. Apart from the crankshaft locking tool, there were no other special tools needed for my car (2003). The other car which had the hydrualic tensioner aslo needed a special little 'fork' type tool (in the above kit) to hold the damper back...you could easily make one of these tho (manual gave dimensions for this). Also there is no need to take the cam sprokect off...and as you can see from my pics my sprocket was turned right back against the slots (anti clockwise). I locked the camshaft in place with a 6mm drillbit (chuck end obviously)...through a slot in the camshaft hub and the 6mm 'locking' hole in the head.
The extra work involved to do the job like i did means the following..
Disconnect and drain radiator hoses (dead easy..just 2 spring clips)
Disconect headlight cables (where they plug into light clusters)
Disconect 3 plugs underneath the power steering reservoir cover (Cooling fan, bonnet switch,AC clutch).
Disconect another plug going to the A.C compressor (at bottom, beside compressor..its a green plug, single wire)
Disconnect the air temp probe in front of the radiator
Remove 2 securing bolts for the power steering 'cooling loop' at bottom of radiator.
Unbolt the A.C radiator and fold it out of the way (if your car has A.C)
And last but not least there are a 3 torx bolts ( 2 on drivers side, one on passengers side) at the side of the front panel.
The panel should now come away complete...and give unprecedented access like the above pictures. The only other special tools needed are a torx bit set (3/8 drive is my preference), as there are various fastners which are torx. Just take your time and all will be well
To 59ctd :
My car is a UK spec 2003 Passat 130 P.D Sport. I'm not sure if you have the Sport model in the States? It has the 6 Speed manual close ratio gearbox, 15mm lowered/stiffer Ebaich springs, uprated Sachs dampers, 16" Road America wheels and sports seats. It also has the usual stuff like climate control, Leather 3 spoke steering wheel, auto rain wipers, auto rear view dimming mirror etc etc. All this is factory stuff.
Whats not factory stuff is the remap i did last week to around 170bhp...sweet
Hope that helps
Stick
P.s remember to use the correct VW G12 antifreeze/corrosion inhibitor...2 litres should do.
