http://www.amazon.com/ARB-10800472-Fridge-Freezer-Quart/dp/B002Q1INDM/ref=pd_sbs_la_2
Thinking about getting one of these for an upcoming roadtrip... wondering if anyone has any/some experience with them...
May or may not circumvent the rear plug to always hot, the fridge is suppose to use intelligent software to kick off if line voltage drops too low, so in theory should be able to leave it always hot and not worry about battery discharge... (It says the software has 3 diffferent settings with a different voltage cutoff for each one)
With only drawing .7 amphours while maintaining temp, it wouldnt drain the battery too quickly
Anyone know what kind of voltage drop the rear 12V plug experiences?? (reading their reviews/forum, the input line voltage can be an issue, not sure what gauge wire VW used of the rear 12V)
