740GLE
- Joined
- Aug 19, 2009
- Location
- NH
- TDI
- 2015 Passat SEL, 2017 Alltrack SE; BB 2010 Sedan Man; 2012 Passat,
This makes 0-2 of me vs garage doors. first time was scraping the garage door hinge across the back hatch of the wagon for about 5" which required a minor respray. This time I snagged the back roofline (including the roof antenna) against the bottom of the door backing up before the door was fully open.
Needless to say the antenna is raised up by about 1/8 of an inch at the back (let alone the grit scrapes on the paint). I've tired pressing down on the antenna but i think the sheet metal was tweaked enough that the only source of solution is dropping the headliner and retweaking from the inside.
Anyone have any tips of dropping the headliner enough to grab onto the antenna and retweak.
My guess is pull the side rear plastic parts off then slowly work the headliner down enough to gain access, just not sure of the fine details.
TIA
TIA
