microsoot
Hi:
I am having a cold start problem:
Situation:
Car cranks over fine when warm, but when cold the starter is slow to crank, then, dies after a few seconds, if I continue to engage starter there is a noise behind the instrument cluster, not sure exactly how deep in but from behind the instruments, it electrically groans for a second and a half, then the tripometer,will reset to zero.
I do have new engine glow plugs, and harness, and no mil on.
The glow plug light comes on ok, and stays on longer when colder, ok.
I am able to pop start it, because it is parked on an incline, and it starts
right up, and ignites the fuel ok.
I had the battery, alternator, and starter inspected, ok.
The battery does pass a load test, but after this situation happens, it loses some charge, so I suspect a high current short.
All the cables are clean and tight.
Can anybody??, help me out as I am considering the coolant glow plugs circuit to be suspect.
I was thinking the easiest way to disconnect the coolant gp's was the fuse removal from battery fuse box.
Because I hear a groan from behind the dash, I want to take the cgp relays
out of the circuit, but that is where it gets shady??
How should I go about this problem, I have a beetle and have to locate the gp module's/relays first??
I also noticed there is a small heating element on that circuit, going to the
CCV on the valve cover, which is suspect also.
Any takers???
Situation:
Any takers???
