DeafBug
Gone but Never Forgotten: Requiescat In Pace
I was doing a timing belt last night on a car that was on its third change. Well just the last step before I could take off the Harbor Freight engine support, the bolt acted weird.
Here is what happened. I put the top engine bracket piece in and installed all 4 engine mount bolts. All four were torqued. I was going to do the +1/4 turn on each of them. First 3 went without trouble. The fourth bolt stripped the threads in the engine support piece. I just barely started doing the + 1/4 turn. I will use degrees to make it clear. A 1/4 turn is 90 degrees. So as I turned about 20-30 degrees, the bolt suddenly felt loose. I continued to make the 90 degree turn and it was way to easy. So I knew something was up. I took the bolt out and it didn't have any signs that the bolt was twisted or stripped. Then I put it back in using a socket wrench and try to tighten it. It never got tight. I can turn forever. (It reminds me of that oil pan drain plug I had two years ago, which I end up replacing the pan.)
It was something I had thought about this issue like 10 timing belts ago. I just never got around to post this concern until it happened. Especially now is a great time with the issue on Lemforder tensioners.
The replacement part number for the engine support is 038 199 207 H. It is called "support" on the ETKA. At vwparts.com, it is $78.04. I figure dealership cost around $90-100.
That engine support is made of aluminum and you use steel bolts to tighten it. It may be alright on the first timing belt change. But after that, it starts to bring up wear and tear on the threads inside the engine support. Torque to 44 ft/lbs plus a 1/4 turn is more than it could handle on repeated timing belt changes.
The concern with Lemforder tensioners now is that even thought most of us have our first or second timing belt done. Doing the tensioner replacement will make it 2nd or 3rd on such a low mileage.
What I want to know is that is there another solution to the problem without possible of stripping the threads in the engine support? There has to be another way or something. One thought I had was not to turn 90 degrees but to 60-70 degrees. Will it still hold?
The owner told me that it is really stupid of VW to do that and as a timing belt changer, I should carry a few spares on hand so that if it happens again, I could sell my piece so that we can get the person back on road instead of being stranded. I thought it was a nice idea especially if you are doing timing belts on a Sunday or after hours.
