richmondvatdi
- Joined
- Feb 5, 2005
- Location
- Chesterfield, Virginia
- TDI
- 2005 Passat Wagon 5-speed,2003 Jetta GL Wagon, 2003 Jetta GLS Wagon, 2013 CC 2.0T
I just had installed the Whitbread solid flywheel and Clutch Masters FX300 (Kevlar) clutch. I was looking forward to a nice smooth engagement but it has been the complete opposite. When starting from a dead stop, as I let the clutch out it shudders badly until completely engaged. In order to reduce it to a tolerable level, I need to get the engine up to 2,000 RPM and release slowly. Obviously that is not good for the clutch, and something else is wrong.
Matt Whitbread seems it is likely caused by a bad CV joint or axle, a bad motor mount, or a bad transmission mount. I believe the axles are good as I just replaced outer boots on both. Grease was clean (no grit) and joints were nice and tight. We replaced a bad motor mount about 10,000 miles ago. Transmission mounts seem OK also.
What leads me to believe that it is not a problem of the clutch itself is that the old eBay FX Racing Stage 1 clutch and DMF (installed by the PO during the 5-speed conversion) was grabby also but not nearly as bad.
Any other suggestions as to what could be causing this? The car is virtually undriveable as it is right now.
