RNS510 Firmware & Maps Info Thread
Status
Not open for further replies.
tadawson
Lewisville, TX
2013 Passat TDI SEL, 2015 Passat TDI SEL
I thought the cease a desist was only on the maps - the firmware comes from an entirely different company.
- Tim
Lightflyer1
Round Rock, Texas
2015 Beetle tdi dsg
You may be correct, but I didn't get it, it was only mentioned in this thread and initially firmware and maps and VIM were being distributed. I don't remember it being specified which company sent out the letters.
LokiWolf
Richmond, VA
2013 Passat TDI SEL
For clarity. It was HERE the marketing company for Navteq that sent me the C&D. So to be safe I stopped distributing everything. There are others who are.
LokiWolf
Richmond, VA
2013 Passat TDI SEL
It's the latest available for my unit....
What he said. 1140 is the newest Firmware the first generation 510's can go to. Just like 4366 is the newest my 2nd Gen unit can go to. The 3rd Gen's are still getting updates, but most are l in the factory with 5374.
TDISam87
Calgary
2014 Jetta TDI
PM mk3vr6me on the golfmk6.com forums for the 4366 FW link.
He'll be happy to help you :) very nice dude
Al Fischer
Clovis, California
2014 Passat SEL Premium
Unit Type
I am trying to understand which unit I have J,K or what?
HW = H21
SW = 4369
Nav = 7963
Delivery Part Number 3C0035684J
I want to update the fimware and NOT brick it!
Al Fischer
Clovis, California
No, you have a revision J. It's the last letter of the part number. You need firmware 5378. HW stands for hardware.
I have 5378 but LokiWolfs post at the beginning of this thread states:
"5378.... Nobody has tried because there is a High likely hood it will brick
a J unit or older"
Has anyone actually done 5378 on a J unit? (don't want to be first!!)
Al Fischer
Clovis, California
Thanks for the help.
Greatly appreciated. Can't get any help on this issue from the dealer. Customer care was pretty good though. But they only are upgrading the Map Noth the firmware!
I think I will apply the MAP update first. Kind of ridiculous that a 2014 comes with a signifigantly down level product. VW needs to correct this!
40X40
Experienced
Kansas City area, MO
2013 Passat SEL Premium
HW = H21
SW = 4369
Nav = 7963
Looks like an H to me. Good luck!
Bill
Sorry about the confusion.
Bil
saragon1
Honolulu, hi
14 jetta
Radios with sw 4369 can be updated to 5378 no matter the revision code. Some j versions came with ssd's which require the new sw. 4366 and below are for hdd.
Salsaman06
Texas
2013 Passat TDI SEL (sold back to VWoA Dec 21, 2016)
I have a revision J unit with H21 and I've loaded 5378 on mine. It updates the part number to a revision L.
Your update worked because your hardware version is H21. It is my understanding that you will "brick" anything less than H21 if you attempt to load software version 5378. My '13 has a H02 version - last software I loaded was 4366 which I believe is the latest avail for a H02 revision. (and FWIW I have "J" at the end of my part number - which really doesn't mean a whole lot)
Salsaman06
Texas
HW = H21
SW = 4369
Nav = 7963
You have a third generation RNS510 (H21) so the software version 5378 should work for your unit.
LokiWolf
Richmond, VA
2013 Passat TDI SEL
SalsaMan06, and BarryT82 are dead on right. When I did that update to the first thread nobody had loaded 5378 on a J unit, and we had not discovered the HW pattern for that revision. Al, sorry for the confusion, and thanks for reading and picking up on the clarity that needs to be made. I will revise it later this evening when I am on a full size keyboard and clarify.
Fixmy59bug
Las Vegas, NV
2015 Passat TDI SE
Quick question regarding hardware and firmware...
This little snippet was taken from my latest VCDS scan:
Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
Part No SW: 3C0 035 684 J HW: 3C0 035 684 G
Component: RNS-MID H02 4366
Revision: AB001001 Serial number [hidden by me]
Coding: 04090042010000A6000B
Shop #: WSC 09003 957 00200
VCID: [hidden by me]
With the HW part number of 3C0-035-684-G and a hardware of H02 4366, does that mean it is as high as it can go with firmware updates? or does Part No SW 3C0-035-684-J mean I can use up to the newest firmware updates?
It is a 2013 model year bought in November of 2012. So I believe it should have the HDD and not the SSD.
mattfrayage
southeastern wisconsin
2015 passat NMS TDI SEL Premium
It cannot accept 5374 or 5378 firmware due to the SSD units different disk drive kernel drivers A.F.A.I.K.
Fixmy59bug
Las Vegas, NV
2015 Passat TDI SE
Ok, so 4366 is as high as I can go.
Is it reasonable to assume there will be no more firmware updates since they have moved onto newer equipment?
LokiWolf
Richmond, VA
2013 Passat TDI SEL
That is my assumption. That happened with the first Gen units, they stopped at 1140. The second Gen's go to 4366.
Status
