TDI817's BRM
Munisign and TDI817, what's the latest? Any dyno numbers? How are the cars running?
I'm running my PD 150 injectors with PP 1043 nozzles. Dyno a week from Saturday and will post the result. So far the new nozzles have improved the overall linear effect I experienced before but maybe more so. It'll be interesting to see the new numbers although on a different dyno.
I'm currently searching for a buyer for my PD140 turbo, Its bran new, never installed still in the box.
I spent
Lots of money on Race 783 injectors having them mounted and calibrated and then after I found out they are too much for a PD140 turbo.
So I'm going to buy a GT2056 wastgated turbo, I just cant decide between water cooled or not. (I like the water cooled option because with out an EGR system I have nothing to help with warm up. I also like it because my 1000Watt frostheater will warm up the water cooled turbo too!)
Not much progress has been made with my car, the SB stage 2 endurance clutch is installed with 14lbs single mass flywheel. I've got about 10,000km on the new clutch (6,250MI) and its just recently started this weird squealing sound, Metal on Metal sound. Like squeaky brakes. but only as the clutch is slowly engaging. If i'm quicker with the clutch it wont squeak but it will be a jerky ride. we have had about 3 weeks of rain and the problem started maybe 3 weeks ago.... And I've been replacing a lot of light bulbs lately Tail light, head light, licence plate light, side marker light. all within 2 weeks.
Anyway I've got enough military commitments to keep me busy/away from home until at least February/March time frame.
So far my parts shelf has on it:
PD140 turbo with smart actuator (ID parts)
2.5" SS down pipe (ID parts)
2.5" SS cat-back exhaust (tectonics tuning)
BEW injectors (forum member) & R783's mounted & calibrated (ID parts & DBW)
0-30 PSI boost gauge & dual column gauge pod (New South)
PD150 intake manifold (forum member)
57MM race pipe (forum member)
I have a stage 2 frank06 cam shaft kit on order
I still need an EGT gauge & probe, and i've been saving my pennies for an LSD.
