I agree you don't want to be using any 15w40 in the winter. I use 5w40 year around with excellent results in an unheated garage in the Chicago area. Using a 5w30 will damage the vavletrain so I storngly suggest no flip flopping between oils. The normal clatter at start up is normal and I usually hear it for 3-4 seconds tops. If anything this is a good sign the lifters are refilling with fresh oil effectively cleaning them out everytime you start the engine.
The lifters do not recieve any oil pressure from the engine. How they work is they draw in oil that is dripping off the cam bearings into the lifter bores. There are ports on the sided of the lifter bodies that draw oil into the lifter when excessive clearnve between the valve and cam lobe is detected. The lifter then expands sucking in oil takiing up the play in the valvetrain. Since the oil is thicker when cold the oil takes a few seconds to get into the very tight confines of the lifter bores.
By stopping the oil from getting into the intake you stop any chance of the intake plugging.
The best thing to do is use Amoco Premier or some other high cetane fuel. With everything on the car intact you will never get intake plugging.
If that is not an option the CCV mod is your only way to prevent plugging. There are other ways such as joining Epsilon in addition to the CCV...
DB
