So I've been fighting this silly oil leak around the filler cap for some time.
I already replaced the gasket with a brand new one, i even doubled up the gaskets just to make sure there's enough down pressure on the gasket to seal the oil (new one touching the head). That slowed down the leak, but didn't stop it entirely.
I normally wash out the head cover every time i change the oil, so that's how i know when it starts and how far it goes. I did notice that when i use the pedal a bit harder than usual, it tends to leak more - i would say anything over 3k - although it's hard to watch the leak as i'm driving.
The rubber collar fits snug around the neck of the filler hole, but doesn't seal it (don't think it's meant to).
Here's the cap with the leak around it - circled in red
This is the back of the engine as the oil moves down:
On a slightly separate note, the dipstick gets oiled somehow also ... no idea how, as there's nothing in front of it to blow oil on it the way the pattern suggests (just on that front face of it):
Here you can see what's in front of that dipstick
Any ideas on these, but especially the top filler cap leak?
