OK everyone got my car back Monday. They kept it 7 days. Here is what was on my invoice:
" 20560 11.30 found metal debris in high pressure pump and fuel system, fault p0087, high pressure pump separated internally contacted vw tech support for information on vehicle concern, sent pictures and gff log to vw tech support sent fuel sample and high pressure pump out for testing, recommended to replace fuel system, replaced fuel tank, fuel pump in tank, secondary fuel pump, high pressure fuel pump, all fuel lines from tank to injectors, replaced fuel injectors and fuel rail, replaced fuel filter housing, adapted fuel injectors to ecm, performed fuel system bleed with scan tool at least 3 times, cleared fault and sent log online, road tested vehicle for operation and performance-test good. mileage 20569."
Parts list as follows:
1 03L-130-301 PIPE
4 059-130-216-C PLATE
2 N-911-316-01 BOLT
1 1K0-127-400-K FUELFILTER
1 1K0-201-293-D PIPE
1 1KO-201-294-C PIPE
1 1K0-919-050-AB FUEL UNIT
1 5NO-906-129-B FUEL PUMP
1 1K0-130-307-BG PIPE
1 1K0-200-059-BH PIPE
1 03L-130-089 FUEL DISTR
1 03L-130-321 PIPE
1 5NO-130-307-J PIPE
1 1KO-130-307-BJ HOSE
1 03L-201-360-G FUEL LINE
1 1K0-919-133-D WASHER
1 1KO-201-060-GP TANK
4 03L-103-113 COVER
1 4A0-820-199 TIE WRAP
1 03L-919-824-C TEMPSENDER
4 WHT-000-884 SEAL
2 5N0-906-221 MOUNTING
1 03L-130-235-S PIPE
4 03L-130-277-A INJECTUNIT
1 03L-130-301-B PIPE
1 03L-130-301-C PIPE
1 0SL-130-301-R PIPE
1 03L-130-755-A PUMP
1 WHT-002-244 NUT
8 N-904-465-02 NUT
3 N-911-803-01 BOLT
The car seems to be much more robust than before, even when new. I conclude the pump was defective from day one? Maybe just my imagination as it was probably just diminishing in its performance curve over the last 10k miles. Seems to be performing well at this point!
I hope all this information will help others....
